Czar of C.R.A.P.
POP quiz caliper seals
Just a pop quiz to see who knows why there is a yellow mark on the outside of the square caliper piston seal. There is a real reason.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Czar of C.R.A.P.
Well appears to no takers on the pop quiz. The reason is so you know if you rolled the square seal inside out while installing. If after putting the seal in you see the yellow mark you take back out and reinstall. Not as easy to roll the small square seals but larger ones like in auto transmission pistons are not that hard to install wrong. Just a note after rebuilding calipers this morning.
Good to know. I'm about to re-build mine in my 85 Cab. Spot on timing.
Just because I don't care doesn't mean I don't understand! Gordon Ost '85 Carrera Cab '01 Durango 5.9 R/T '00 Taurus SE- SO's canoe '97 KTM 250EXC FOND MEMORIES: '68 Pont Ventura Conv 389w/trips '99 BMW 323is '71 TR-6 very first car '73 TR-6 restored it-Concours winner '67 Lincoln Conti-suicide doors '70 Challenger-340-6pack slap stk '69 Dart GTS 440-4bl-4spd '73 Moto Guzzi Eldorado |
