Window track
My driver's side window came unglued at the bottom where it is pulled down and pushed up. I don't know the exact name but it holds the window at the bottom.
What is the best glue to use to re attach. I was thinking of silicone but thought it best to ask here. This is also a good time to lube up all the mechanism inside the door. As a side note NO RUST! I am happy!! Thanks |
When that happened to me, I used the same adhesive/sealant used to install windshields. Any winshield place should be able to sell you a tube.
window track
Thanks Don good idea. Did you go through and lube up all the mechanism? If so what did you use..
Terry |
| All times are GMT -8. The time now is 08:39 PM. |
