-   -   How do I tell what exact year my engine is? (http://forums.pelicanparts.com/porsche-911-technical-forum/224040-how-do-i-tell-what-exact-year-my-engine.html)
86 911 05-30-2005 09:27 PM
I have a 1978-1979 911 3.0 engine in my 911. When I first registered to this forum, I asked what year my engine # was from, and someone said it is a 1978-1979 3.0. Is there any way to tell if the engine is either a 1978 or 1979, or were the engines built exactly the same in the two years where you cannot tell the difference at all? Is the only solution carbon dating? ;)
Sumotang 05-30-2005 11:01 PM
whats the engine number?
Sumotang 05-30-2005 11:05 PM
If its 6280001+ then its a 78 engine
If its 6290001+ then its a 79 engine
This assumes its a from a US car.
Bobboloo 05-30-2005 11:14 PM
Both 78' and 79' were the same engine type. So the type number i.e. 930/03 or whatever won't tell you. The serial number however will. A 78' motor will have a serial number like 6x8xxxx. A 79' motor will have a serial number like. 6x9xxxx.
So basically the serial number 6180129 stands for.
6 = 6 cyl
1 = eng type (Japan 930/05)
9 = year (1979)
0129= sequential no.
86 911 05-31-2005 03:14 PM
Thanks you for the information. My engine type is 930/04. Where on the engine would I find the serial number???
Thanks.
Bobboloo 05-31-2005 04:48 PM
It's located vertically on the right side of the engine fan support.
930/04 = 78' to 79' US 49-state 3.0
Navaros911 05-31-2005 05:07 PM
One thing to keep in mind is that the model years don't run from Jan to Dec.
If I'm not mistaken it is from Sep to Aug, so a '79 engine could have been produced in late '78 (Sep, Oct, Nov and Dec). That may have been the reason someone said it is a 78-79 model.
86 911 05-31-2005 05:17 PM
Bobboloo and Navaros,
Thanks for the replies. The engine # on the fan support reads: 6381340. Would this be correct then?
86 911 05-31-2005 05:37 PM
Update:
Just went into the garage and double checked both numbers. The engine type is really 930/03, and not 04. Now it makes sense. According to this webpage I get more torque than the U.S. model! SWEET!!!! This made my day!: http://www.adelgigs.com/911scproductiondata.shtml
I get 28 more NM than the U.S. model! :D :D :D
86 911 05-31-2005 07:32 PM
One more question, while I'm at it. My serial number is 91516630R on my transmission. What year would mytransmission be?
Thanks!
edit: I found the location of the transmission s/n.
