-   -   SC Steering Rack DIY Bearing Replace (http://forums.pelicanparts.com/porsche-911-technical-forum/224112-sc-steering-rack-diy-bearing-replace.html)
Flieger 12-20-2012 08:10 PM
Thanks!
Nickshu 12-20-2012 08:39 PM
So cool...more pics of your restoration anywhere on the board?
KTL 12-21-2012 10:42 AM
Does the needle bearing truly need replacement? My experience has been these can easily be disassembled and cleaned. I recently disassembled a rack and the Torrington bearing was easy to "rebuild" by picking out the needles, clean them off, smear the cage with grease and stack the needles back in there.
Thanks to Nick for the link to MSC. Type in "1712 bearing" and the IKO bearing for $8.54 comes up!
RWebb 12-21-2012 12:34 PM
why haven't any of you guys figured out how to hot rod the steering rack yet?
DaddyGlenn 12-21-2012 01:41 PM
I painted flames on mine. :D
Not really;)
KTL 12-29-2012 11:28 AM
Because its real low on ROI
Quick Ratio Steering Porsche Part Distributed By Patrick Motorsports
RWebb 12-29-2012 11:41 AM
low ROI has not stopped many Porsche owners
BTW - who is going to weigh their rack & etc. -- just to let the Borg add to the database
Reiver 12-29-2012 03:56 PM
very nice...looks like someone has been to the powdercoater of late.
patkeefe 12-31-2012 01:28 PM
I have to change my boots and tie rod ends. As the car is engineless, up in the air, I may as well look the rack over and see how it held up. I do think I'll change the grease and bearings and inspect the puck.
Nickshu 12-31-2012 02:04 PM
It costs less than $9. Enough said. Personally I don't want to do this project again for another 30 years so I would recommend just replacing it.
javadog 01-01-2013 05:34 AM
Anybody ever try ordering any of the repair parts from Porsche? They seem to still offer some of the seals, o-rings and other wear parts for the 914-4 steering racks and I'd bet many of the parts are the same.
JR
KTL 01-04-2013 07:46 AM
Why spend $9 plus shipping when you don't have to? My point is that "rebuilding" this needle bearing doesn't get any easier. You hose out the grease with brake cleaner and the needles literally fall out of the bearing cage. Hose out the grease in the cage, wipe everything clean with a paper towel and reassemble with a high quality grease. It takes about 5 minutes of your time.
Plus the bearing that's original to the rack is most likely of better quality.
Just my opinion................
Jaybird12 01-04-2013 08:24 AM
But its been running dry for ,,,,,,10-15 years minimum. It doesn't matter how high quality it is there's bound to be wear on the bearing. Even a quality bearing is a small expense for one less weak link in the proverbial chain. My opinion.
Luc Bernier 01-04-2013 09:01 AM
have the same problem on my 78 SC.
that's my project for this spring, since the car is stored away for the winter. Since I will have someone check out my play in the steering wheel, how much work do you figure it will be ? hours ? parts ?
I want a steering wheel feeling that will make me enjoy the car at highway speed as well as on country roads, wich is not the case right now.
thanks for advices
Luc
KTL 01-07-2013 07:57 AM
If the bearing was truly running dry it would seize up or really increase the steering effort . All i'm saying is that the bearing is a VERY simple piece to take apart and look at. Needle bearings are very good at telling you when they're bad. They leave their mark on the shaft in the pattern of the needles.
BTW the lower bearing is indeed pressed onto the pinion. You remove the circlip and shims and then have to pull it off with a tiny puller arrangement. To reinstall, a socket of suitable size in your workbench vise works great.
Luc,
The steering rack rebuild process is not hard. If the tie rods are already being replaced, then the work to get the rack out is even easier. After the tie rods, the rack mount bolts and the upper shaft u-joint connection are the remaining spots to disconnect the rack from the car. After that, it's just a matter of taking apart the rack which is quite simple.
Jaybird12 01-07-2013 08:41 AM
Originally Posted by mikeatfhc (Post 4038657)
I can finally ad something to the knowledge base of this board...:D
I just tore into my front suspension this last weekend. Since I was in there itis struck me so I thought I'd pull the rack and check it out. It's a pretty simple device so not much to say *but* that be careful when you pull everything apart - the pinion bearings up in the top of the rack (not behind the access covers) are loose needle bearings.
They stayed in the race just fine until I took everything apart and started spraying degreaser into the housing to clean it up... the degreaser melted the grease and all of the little needle bearings came out and (luckily) fell into my parts tray and not on the floor and under the garage door. Be forewarned...
I consulted with a machine shop friend who assured me they are fine for reuse... just dap grease on your finger and set them back in one by one. I finalized the procedure by 'packing' grease in there and rotating them with my pinky finger.
The rest of this is a pretty easy process - very glad I did it.
(My bearings were fine so I did not replace them.)
Here's a photo after cleanup - the needle bearings exist in the center top shaft staring at you in the face right now...http://forums.pelicanparts.com/uploa...1215049500.jpg
http://forums.pelicanparts.com/uploa...1215049532.jpg
Sorry - I forgot to count the little buggers for posterity.;)
http://forums.pelicanparts.com/uploa...1357580450.jpg
I had 26 in mine.
Craig_D 01-21-2013 07:05 AM
Originally Posted by Jaybird12 (Post 7194042)
That's interesting. On my '78 SC, I had 29 needle bearings.
http://forums.pelicanparts.com/uploa...1358784278.jpg
DaddyGlenn 01-21-2013 07:19 AM
I just replaced the bearings when I did mine. Very cheap insurance.
frankc 01-26-2013 04:25 PM
I just disassembled mine today. Interestingly, the needle bearing from my '77 had 26 rollers in it just like Jaybird12.
And amazingly, the 35 year old grease appeared to be in pretty good shape, as were the bearings and puck. But as folks here have said, as long as I've got it to this point I might as well replace the bearings and be done with it for another 35 years.
Question - is a "caged" needle bearing suitable for this application? This is the only 1712 bearing listed at MSC. I guess this avoids accidentally losing the rollers.
Shell Needle Roller Bearings - Radial Ball Bearings | MSCDirect.com
Also, does anyone know where to order the O-Ring used at the top of the pinion?
Jaybird12 01-27-2013 03:34 AM
I just used a generic o-ring from an o-ring kit I have. Can't see it being a problem as long as its matched in size and diameter.
