Meka's Avatar
911 leaning to left
I just noticed my 84 Carrera is slightly lower on the drivers side. Other than improper suspension adjustment, what would cause this?
1984 Carrera
Old 06-02-2005, 10:50 AM
pwd72s's Avatar
Broken sway or torsion bar? Just guessing here...but it's worth having checked out. (edit) Could also be shot bushings, loose spring plate, any number of things.
Old 06-02-2005, 10:55 AM
I have the same problem. My mechanic says the only way to fix it is to lay off the donuts.
Old 06-02-2005, 10:56 AM
thunderdenton's Avatar
Reindex the torsion bars may help, unless they really are broken.
1984 ROW Cab
Old 06-02-2005, 11:02 AM
durn for'ner
livi's Avatar
David,
Are you referring to the procedure of readjusting the caloric index ?
Markus
Resident Fluffer
Carrera '85
Old 06-02-2005, 11:09 AM
Markus,
That's exactly what I'm talking about.
Old 06-02-2005, 11:18 AM
Zeke's Avatar
Set up for NASCAR? ;D
If a t-bar breaks, the car will be seriously down on one corner.
Old 06-02-2005, 12:09 PM
echrisconnor's Avatar
Is it seriously leaning, or just a little bit? Have you measured your fender heights all away around to see if it's just one corner?
A broken T-bar will throw things way off, but a dead gas-charged shock will also affect the height and won't be as obvious from a performance standpoint.
'76 911 Carrera 3.0
Old 06-02-2005, 12:21 PM
Used Up User
imcarthur's Avatar
Rear bushings. Mine had a list last year to one side. About 3/4" & visible from the rear.
Replacing the rear bushings did the trick. Of course I also did shocks, re-indexing, alignment etc 'while I was in there'.
Ian
'87 Carrera Cab
Old 06-02-2005, 12:38 PM
