Would you add an oil cooler?
Now that the warm weather is here, would you add an oil cooler for the temperature indicated?
The car is a 69E with a '82 3.0SC running with PMOs. Is this too hot already? Thanks.
'72T Targa w/2.2S MFI (sold circa 2010) |
Gon fix it with me hammer
it's smack in the middle , it's not even near the read zone.
reasonable operating temperature mine has numbers on it , and it would read 100C , which is fine your lower red, would be 120 C , top of your yellow , would be my 150C any area on your clock with colour , i would avoid. unless this is a readout in the winter, and you expect to drive long hauls in 40C + weather during the summer, or track race your car on the circuit , i'd say your fine
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 06-02-2005 at 08:07 AM.. |
Somewhere in the Midwest
That temp doesn't look dire...but I would plan on adding a cooler. Start looking for used hard lines and a t-stat... and at least a 28-row brass cooler.
When the temp and humidity starts to climb in the City...you'll wish you had a cooler...esp. if you are stuck on the "Expressway." |
Svandamme, thanks for the info.
Souk, I will keep my eyes open for the parts.
Nobody
fwiw, i just purchased the under the body to f fender lines, t-stat, mounting hardware from salvage shop for $550.
