Camber and toe-in bolts
Does anyone know what size Allen wrench is needed for the eccentric bolts on the spring plates of my '72. They are bigger than any I have in the shop.
Mike.
1972 911T, non-sunroof coupe.
Old 07-10-2005, 06:19 PM
Used Up User
imcarthur's Avatar
Hi Mike
12mm & tough to find. Not @ Cdn Tire or Home Depot etc. You can order through Napa stores. I have one here, you're welcome to borrow, but I'm a ways away . . .
See My Alignment for my progress . . . mostly done now.
Ian
'87 Carrera Cab
Old 07-10-2005, 06:28 PM
You can always cut off a piece of an allen wrench and turn it with a 12mm wrench.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 07-10-2005, 07:13 PM
Bandwidth AbUser
Jim Richards's Avatar
I picked up a 12mm at Sears and cut it down a bit to fit in the area I have to work with.
Jim R.
Old 07-11-2005, 04:48 AM
I would rather be driving
jpnovak's Avatar
Yep, I did the same as Jim.
Old 07-11-2005, 06:26 AM
