-   -   Cold Start idle setting (http://forums.pelicanparts.com/porsche-911-technical-forum/224565-cold-start-idle-setting.html)
StayGold808 06-03-2005 03:45 AM
Hi,
On a carrera 3.2, how do i set the idle for when the car starts cold? Is there a screw which you can adjust it with?, or is it more complicated and to do with the fuel injection? or the AFM?
BReyes 06-03-2005 05:16 AM
What is it doing?
StayGold808 06-03-2005 05:55 AM
When the car is started cold, the idle is too low, and it stalls. however if i apply some accelerator, i can sort of "make" it idle, and then drive. When the car warms up, it idles fine.
StayGold808 06-03-2005 09:35 AM
wow.. this is the first time this forum hasn't been able to help me....
ZOA NOM 06-03-2005 10:34 AM
There is a small yellow cap on the idle screw just below the throttle body. It should be plainly visible from directly behind the car. I'll take a picture and post it in a minute...
ZOA NOM 06-03-2005 11:07 AM
A deep 7mm socket will fit over the yellow cap.
http://forums.pelicanparts.com/uploa...1117821081.jpg
There is a procedure for adjusting the idle. You place a jumper between these terminals and adjust the idle screw for 800 RPM. If adjusted correctly, you should hear no difference in RPM when the jumper is removed.
http://forums.pelicanparts.com/uploa...1117822030.jpg
DonMo 06-03-2005 01:51 PM
I would look for vacuum leaks too. They don't just idle down for nothing and 3.2's intakes have a tendency to pull that gasket in if not tight enough. Get some fuel injector cleaner from you local parts store and spray around the base of the intake. Be carefull around the air intake. If you want to see what you are looking for, spray a little into the air intake and the idle will increase. Vacuum leak causes the idle to decrease.
StayGold808 06-03-2005 09:07 PM
Okay thanks alot!
I'll check all of these.
So there is or isn't a separate idle setting for a cold start?
ZOA NOM 06-03-2005 09:23 PM
No separate setting. The DME controls the idle, and will ignore the O2 sensor for the first minute or so until the motor warms up a bit.
StayGold808 06-03-2005 09:40 PM
so if it idles fine when warm, could the idle setting not be the problem?
mjshira 06-03-2005 09:52 PM
I would be careful in messing with that, the DME should be able to handle the adjustment between cold and warm.
ZOA NOM 06-03-2005 10:21 PM
The idle adjustment will affect both cold and warm idle. If your car is idling normally when warm, then I would look at your Idle Control Valve (ICV), which will vary the engine speed based on a varying signal from the DME. During warm-up, the DME sends a programmed signal to the Valve, and ignores the O2 Sensor. Once warm, the O2 sensor signal will cause the DME to vary the reference to the ICV.
StayGold808 06-03-2005 11:06 PM
OK, so where is the ICV located?
DonMo 06-04-2005 03:21 AM
Check the first picuture above, the component right below the idle adjustment screw is the ICV, it has an electrical connection on the left and two black hoses into it top and bottom. I would take it off and clean it with fuel injection or carb cleaner (inside). It should rattle easily when shaken.
ZOA NOM 06-04-2005 09:04 AM
Red arrow is the ICV valve. It can get gunked up and not operate smoothly. Shoot some carb cleaner into the valve and work it back and forth. Also, it should hum slightly when the motor is off and the ignition key is turned on.
http://forums.pelicanparts.com/uploa...1117900935.jpg
StayGold808 06-04-2005 08:25 PM
alright.. will do!
Thanks alot
