more smoke with pre-muffler
Hello
Does pre-muffler cought out more smoke ?, I has pre-muffler and GHL exhuast installed on my car, I noticed that the car tail pipe cought out more smoke at frist start and then slowly burn up but still see a bit smoke at idle
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 06-03-2005, 02:52 PM
yogi's Avatar
Someone correct me if I'm wrong. I was told as your valve guides wear they allow oil into the exhaust. The heat from a cat would burn this up so you would see no smoke. Unless of course it is excessive then a cat won't even help. On the other hand the premuffler does not get as hot as a cat and has a higher flow. So if there is any oil seeping, it will now show up as smoke in the exhaust.
Jerry Baer
87 Carrera Coupe
Old 06-04-2005, 03:25 PM
oneblueyedog's Avatar
If your car smokes all the time driving around then you have some kind of oil leak in the combustion chamber either from valves guides, piston rings or both.
If your car smokes and then stops smoking when you start it up, it's common and normal. The rings rotate around on the pistons and depending how long you let your car sit, a tiny bit of oil will seep into the combustion chambers- thus the puff of blue smoke.
78SC coupe, Silver Metallic
Old 06-04-2005, 04:23 PM
