Turbo Gang...A PICTORIAL Of Stock 3LDZ versus K27-7200
Well I figured this might by a worthy post, I took some pics of my stock 3LDZ turbo compared to my new K27-7200 today.
Both turbos side by side at first glance look almost identical but when you look at the housings closer you can see why the K27-7200 flows more cfm than the 3LDZ You can see the compressor side is significantly larger on the K27-7200 than the stock 3LDZ and the turbine housing is larger through its entire diameter. I have written down widths in mm as a reference. Mounting the K27 will be easy and will require that I take a hack-saw to the pipe that connects the turbo to the IC and then use a silicone 2" coupling and two T-Bar clamps. K27-7200 on the left, 3LDZ on the right: Notice the difference in widths here written with a Sharpie and in millimeters, 3LDZ on left, K27-7200 on the right: Hope that helps anyone for future and a good reference. Yasin
Ole Skool - wouldn't have it any other way |
