-   -   Ignition Leads (http://forums.pelicanparts.com/porsche-911-technical-forum/224711-ignition-leads.html)
aus911 06-04-2005 02:56 AM
Ignition Leads
Just a quick question, apart from RFI suppresion, what is the reason for the resistors in the ignition leads?
And what effects are there when running without the resistors in the leads?
Those of you who race seriously what ignition leads/setup do you use?
Thanks in advance
Cheers http://www.pelicanparts.com/support/smileys/wat6.gif
Ray
randywebb 06-04-2005 02:32 PM
do you have DME or any other EFI system?
aus911 06-05-2005 12:19 AM
Randy
There is no DME or other EFI system.
The car in question is a 2.8 litre high compression engine using webbers and a permertune ignition system.
Cheers
Ray
randywebb 06-05-2005 10:32 AM
then I wouldn't worry about resistors or resistive wire -- unless you run a radio back to the pit crew
aus911 06-05-2005 11:42 AM
Randy
Thanks for the advice.
