-   -   901 clutch fork problem (http://forums.pelicanparts.com/porsche-911-technical-forum/224794-901-clutch-fork-problem.html)
goose 06-04-2005 08:00 PM
3 years ago i had the pivot bolt on the clutch fork arm changed
yesterday i was driving around and when i shifted to third
the clutch pedal went to the floor (snap sound)
checked the cable under the car ,all ok the clutch fork is loose
,,is the a aftermarket pivot bolt that is better than the factory
i have the 901 model,, i think that the original part was made from brass
also is there a good mecanic in the Montreal area that could fix this for me before the Montreal GrandPrix
All help welcome
Clay Perrine 06-04-2005 08:13 PM
Sounds like you own either a 70 or 71 911. They used a 225mm pull type clutch with a 901 gearbox. I have a converted one in my 914.
They used a fairly weak clutch pivot. The only way to fix this is to pull the transmission. Once it's out, then you can replace the pivot with a hardened steel one, available from our sponsor. If the threads have pulled out of the trans case, dont' try a heli-coil or anything similar. You are only asking for the problem to come back.
Open the trans up and remove all the components, including the differental (now is a good time to replace all the seals). Have a machinest make a top hat shaped insert with the proper threads (8mmx1.25 IIRC). Machine the case to accept the insert as a press fit from the INSIDE of the housing. If this is done correctly, and you put in the hardened steel pivot, you will not have the problem again.
Hope that helps.
