Squeak in driver rear
I have a squeak in the drivers rear. Driving the car, it sounds like a squeaky seat and when you push down on the car from the outside it sounds like it is behind the rear wheel.
Is it a bushing or wheel bearing? I think bushing, but I am some what of a newbie on the 911. If it is the bushing, what is the best one to replace it with? |
Time for Chucks' Elephant Racing Poly Bronze bushes!
It's taking all the control I have to not make a smart aleck comment about a "squeak in the driver's rear"...besides, this forum is too mature for that sort of thing.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Location: member Central PA Region PCA , Home of the Hershey Swap
Sorry I couldn't resist.
![]() Seriously, sounds like the bushings. First, ou can try a spray lubricant first, something with a nonsticky residue like tefon.
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue Last edited by rbcsaver; 06-06-2005 at 09:16 PM.. |
Information Junky
Re: Squeak in driver rear
hey, what you do with the rubber-ducky is your own business.
okay seriously... "it sounds like it is behind the rear wheel." Do you mean, in front of the rear wheel? If the squeak is behind the rear wheel, you may need polybronze bumper bolts. (tic)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I did not even think of it like that, that is funny. I guess I need some oil on my rear! No, wait.
Will strawberry jelly work to put on the bushings?
11 PTT 88 Carrera Coupe - Gone, but trying to buy her back Hook 'Em Horns! |
What is the time needed to replace these? I would like to do all of them when I do it.
Also, what would most shops charge to do something like this.
How do you get it in there? Can someone post a picture of the area in question...............please?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Semper drive!
![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
I don't want to open a can of worms like......take the tire off, take the brakes off, pull the bearing, pull the axle, replace the boots............etc. What's the KISS method on this one? Where do I squirt the teflon?
You might also want to check the sway bar links and bushings for friction.
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
I was thinking about bushings and typed bearings..............I hate when I mix the two up.
If it's coming from the spring plate bushing, and its an original rubber bushing, then the likely cause is metal-to-metal contact between spring plate and spring plate cover due to a deformed bushing. You can see this visually from the outside. In this case grease is useless, you need new bushings.
If it's a plastic spring plate bushing, there is your problem. Replace them. If it's coming from the sway bar bushing, grease may provide temporary relief but you should just replace the bushings - they are cheap and easy.
Chuck Moreland - elephantracing.com - vonnen.com |
Information Junky
