-   -   Proper plug gap for "81 SC (http://forums.pelicanparts.com/porsche-911-technical-forum/225308-proper-plug-gap-81-sc.html)
ejames19 06-07-2005 05:29 PM
Doing the distributor cap, rotor, wires and plugs this weekend. Picked up NGK BP 7 plugs and Bosch for everything else. What is the proper gap for the plugs, been reading around and cannot get a consensus. Owner manual in German being a Euro spec car (makes a difference I believe in proper gap) and am waiting delivery for another week on a 911 maintenance book. Anyone?
walt 06-07-2005 05:40 PM
According to Haynes .028-.032 in.
TerryH 06-07-2005 05:41 PM
Per owners manual
Plug: Bosch W5D
Gap: .028" / 0.70mm
ejames19 06-07-2005 05:49 PM
Thanks for the quick feed back. Do you think the NGK 7's will run to cold or will be fine. I found this plug to be very common choice among all PO in varying models and years.
TerryH 06-07-2005 06:07 PM
Should be fine. The two plugs cross reference as equals.
Make sure the terminals are screwed on tight at the tips. Use dialectric grease inside the boots. I usually put a drop of engine oil on the threads. Only change on cold motor.
ejames19 06-07-2005 06:21 PM
Thanks for the tips. Will do, let you know how all went on Sunday if I'm not back on here an hour into it on Saturday. Thanks again.
