-   -   Speed Odometer Gears (http://forums.pelicanparts.com/porsche-911-technical-forum/225317-speed-odometer-gears.html)
vizail 06-07-2005 06:28 PM
Tha odometer of my 911 is not working. The milage counter is working but it don't register how many miles I have travel from here to there .
Where can I get the famous gear that worn out?
Cordially
VicSmileWavy
Oh Haha 06-07-2005 06:50 PM
Check the search feature, my friend.(Jeez, I sound like a true Pelican.)
Many, many thtreads and info on this. Hollywood Speedometer seems to be the preferred repair shop for this. IMO, I wouldn't even try to DIY. I did and what a PIA! Ended up sending it out anyway. DOH!!!
Fl Ted 06-07-2005 06:52 PM
www.odometergears.com
Erakad 06-07-2005 08:38 PM
Not a bad job for a DIY, take your time and follow the directions in 101, also do the search as directed, there are many detailed instructions (including my own). I'll tell ya, you can spend $100+ for someone to do it for you, or $25 and a couple hours yourself...your choice.
vizail 06-08-2005 04:21 AM
Okay
Thank's all for the Information
Cordially
VicSmileWavy
vizail 06-08-2005 08:49 AM
Gues what..?
I just opened the Speedo as required and found that the gear is completely desintegrated.
The only info. that I have is that the speedo porsche part is a 911 641 545 01 and the speedo runs or is calibrated 85mph and 140km. This is a 1982 SC Targa
I just wonder If someone of knows how many gears.
Cordially
VicSmileWavy
Thrasher 06-08-2005 10:18 AM
Here's my long-winded report on doing this:
http://forums.pelicanparts.com/showthread.php?s=&threadid=196987&highlight=odomet er
vizail 06-09-2005 05:03 AM
Trasher
Very Nice but the las Pix is missing. It will be very nice if you can Post it
VicSmileWavy
Thrasher 06-09-2005 08:54 AM
I have added it. I thought Wayne might pick this up as a tech article, but it never happened.
tHrasher
vizail 06-14-2005 10:29 AM
Broke the tham needle...!
VicSmileWavy
vizail 06-14-2005 04:10 PM
Tracher and Friends
As you can see the Odometer gear has disapear
http://forums.pelicanparts.com/uploa...1118790198.jpg
I disasemble and replaced the gear supplyed by Instruments Gears
http://forums.pelicanparts.com/uploa...1118790296.jpg
I took of the bushing and drill to size
http://forums.pelicanparts.com/uploa...1118790372.jpg
I'm using a WD 40 tube
http://forums.pelicanparts.com/uploa...1118790433.jpg
Fixed ........will try tomorow
http://forums.pelicanparts.com/uploa...1118790477.jpg
Thanks for the help
VicSmileWavy
vizail 06-15-2005 08:36 AM
Fixed and working perfectly
VicSmileWavy
Thrasher 06-15-2005 09:30 AM
Good for you! That WD40 tube actually looks pretty good.
If you have access to either a GPS or radar, you should check the accuracy since the needle was removed.
BigKenSteele 06-15-2005 11:44 AM
I don't get what you mean about the wd40 tube? I did the same thing two weeks ago. Replacing the gear was easy, but I broke the needle shaft too. I ended up sending it to North Hollywood, so I didn't save any money, but I learned the proper way to remove the needle - twist counterclockwise while pulling - no sideload. I would do it again if I had to.
Thrasher 06-15-2005 12:42 PM
I think he's saying his needle (not the shaft, the orange indicator) broke off and he replaced it with a section of a wd-40 aerosol tube
vizail 06-15-2005 01:03 PM
No I meant The shaft...!
I drill the original shaft bearing to the size of the WD-40 size tubing and installed in place of the needle shaft
http://forums.pelicanparts.com/uploa...1118865546.jpg
Sorry I don't have a photo since I was so in to it that I forgot.
Then I replaced the counter face
http://forums.pelicanparts.com/uploa...1118865628.jpg
And then I instaled the counter needle. There is a mark for the counter nedle so that you can put it in the proper position.
I just try it today and it is working perfect
very sory you guys that I din't took pixes because is an alternative fix
Cordially
VicSmileWavy
Thrasher 06-15-2005 01:17 PM
oh, my bad. Now I see. I never got that far into the guts since my needle stayed on the whole time. Very clever - and pre-lubricated with WD-40!
vizail 06-15-2005 01:54 PM
The drilled hole is 1000th of inch biger than the tubing and it moves freely
VicSmileWavy
Mikey D 06-22-2005 08:49 AM
Which Gear?
I have a 85mph/140kmh speedo. I need the gear but mine has broken into little bitty pieces. I was told I need the standard 30 tooth gear. Does anyone else have any knowledge on this?
Michael
Thrasher 06-22-2005 09:21 AM
I don't, but call the guy who makes the gears and sells them at www.odometergears.com - "To contact us please call: 757-593-3478"
