The back-up lights aren't coming on. The
The back-up lights aren't coming on. The fuse box states that the back-up and the fog lights share the same fuse. The fog lights work. Is there a switch or something that I could/should replace?
'90 C2 62K; resealed and updated.
Old 06-08-2005, 11:13 AM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Probably the reverse switch on the tranny, or a wiring booger somewhere.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 06-08-2005, 11:41 AM
the tranny back up light wire connector has two male pins. Pull the connector and check with a test light.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-08-2005, 01:50 PM
Thanks. The lights went on as sson as ...
I unplugged the wires. The ignition was on and the trans was in neutral. They stayed on no matter if the trans was in reverse or not or the wires were touching or not, if I recall my scenarios correctly. Is it clear that the switch is the problem?
Old 06-08-2005, 07:08 PM
Re: Thanks. The lights went on as sson as ...
I'm in a fog over your signature reading '90 C2 ?
is this the car ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-09-2005, 04:42 AM
