ejames19's Avatar
Porsche Crest Unsightly Hose, best replacement? Anyone...
Doing some work this weekend and would like to start giving the engine a nicer look and cleaner. This hose (or piping) just sticks out and looks terrible any suggestions for replacing, if so please describe and dimensions or where to pick up? Pictures.
'No illusion is more crucial than the illusion that great success & money buy you immunity from the common ills of mankind, such as cars that won't start.'
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-09-2005, 05:37 PM
Looks like a dryer vent hose from Lowe's or Home Depot. I'd try AZ, Carquest, etc. and see what they might have for actual automotive applications.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 06-09-2005, 05:42 PM
Looks like you need backdate fittings and some new hose. Either aircraft hose or the foil.
Kevin
Kevin
'79 Coupe
Old 06-09-2005, 05:54 PM
walt's Avatar
If you do a search for spruce aircraft you will find some really good looking hoses that will work.
Walt
82SC 3.0
81SC 3.6
Old 06-09-2005, 05:56 PM
scottb's Avatar
Take a look here . I think you want CAT tubing, which is black.
You've got some cheap dry vent hose there.
1984 Targa
Old 06-09-2005, 05:59 PM
ejames19's Avatar
Appreciate the info, exactly what do you mean wilke3619 by "backdate fittings" not familiar with the term. Spruce aircraft search on general web or pelican? Thanks again,
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-09-2005, 06:00 PM
Engine is Finally Done
it appears you have the large outlet fitting that normally attaches to the blower. With the backdate you have a smaller hose on each side. I could be wrong, its happened before. What year model is your car?
Kevin
'79 Coupe
Old 06-09-2005, 06:10 PM
ejames19's Avatar
'81 SC Euro spec'. I believe your correct about different size on other side, I appreciate the help.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-09-2005, 06:13 PM
Registered abUser
TerryH's Avatar
yeah, search for "backdate heat" or something along those lines. Usually on the left side the turbo vent is adapted to the fan shroud get around the distributor and then a short flex hose is all that is needed. Looks like the PO removed the stock heating system with blower and hoses but left the stock vent there and adapted the shiney bright longish flex hose.
'81 911SC Coupe SOLD
Old 06-09-2005, 06:26 PM
scottb's Avatar
ejames: Click the link I posted. It will take you to Aircraft Spruce.
1984 Targa
Old 06-09-2005, 06:59 PM
Sumotang's Avatar
Thats the original outlet that normally is connected to the heater blower. Looks like the PO has done a DIY job of backdating the heating.
What does the right hand side of the engine look like. It should look like the engine posted by Wilkie3169 if its been backdated properly.
There is a guy on Pelican that makes the back dated components out of fibreglass. Do a search on 'heating backdate' and you will find it.
For reference, here is my car with the orginal set up.
Ventilation Ducting
Hope this helps
Damo
83SC 'Guards Red' - Sold
1994 993 C4
Old 06-09-2005, 07:07 PM
ejames19's Avatar
scottb, the product sounds nice, appreciate the link. Where is the company located out of curiosity? Does anyone have any pictures of what they've put in place if found in engine compartment.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-09-2005, 07:09 PM
scottb's Avatar
They're in Southern California and they have an outlet in Georgia.
1984 Targa
Old 06-09-2005, 07:12 PM
ejames19's Avatar
Thanks Sumotang, hope to get it half as nice as willkie3169. Wilkie3619 absolutely gorgeous engine. WOW. Thanks to all. Wilkie where did you get the hosing!? Looks sharp.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-09-2005, 07:16 PM
