Camber question
I have ordered some new wheel/tires for my C2 Turbo and it seems like they would be completely flushed with the fender walls.My question is i might have to run some neg camber like .5'-1' for the tires to clear the fender lip,would i need to get the whole alignment done again or can i just adjust the camber by itself ?
Thanks |
PRO Motorsports
Changing camber will affect the toe as well. You'd have to reset the toe front and rear if you change camber front and rear.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
What if it's just the rear camber ?
