-   -   Grrrr!!! PO jacking damage (http://forums.pelicanparts.com/porsche-911-technical-forum/225631-grrrr-po-jacking-damage.html)
twobone 06-09-2005 04:55 PM
I just noticed tonight that the PO must have had the car jacked up poorly at some point in the past.
The rear passenger floor is buckled up quite a bit. Its quite a hump. The sills look fine though and the car seems otherwise unharmed.
Is that of any major concern from a structural perspective?
I assume that this could also become a spot for rust to start due to the stress cracks that are sure to be there.
randywebb 06-09-2005 05:15 PM
Nah - just beat it back down -- check the sealing. Be thankful he didn't jack it up under the oil lines...
KCinBR 06-09-2005 05:41 PM
YEP mines the same way....but I can only see it when I'm under the car;) ....I'll probly leave it alone
Sumotang 06-09-2005 08:08 PM
My PO did the same thing and I can only notice it when under the car. At some stage I may beat it back.
Willem Fick 06-10-2005 02:51 AM
Just knock it back with a soft mallet. No problems when I did mine - didn't have a mallet handy, so just stomped on it with a heavy boot...
Kroggers 06-10-2005 06:05 AM
I have a bump on both sides, after I had my wheels balanced and the tracking done last time by a local garage. Unfortunately did not notice until I removed the carpet for replacement. I have a slight bump on the driver-side close to the map pocket, and a rather nasty one under the passenger seat. I will push them both out before fitting the new carpet.
david.avery 06-10-2005 06:23 AM
Don't necessarily blame the PO, I had an inspection station do that once. These guys aren't always the brightest bulbs!
