Caliper rebuild headaches...
Well I have all the pistons out but one! I have soaked it in everything imaginable but one piston will not come out.
Any suggestions or things that have worked for others that have attempted this painful project? Cheers, Derek
1989 964 Carrera 4 Coupe |
I just put a block of wood in the middle that prevented both pistons from completely ejecting from the caliper. I was able to pressurize it with compressed air. I was actually able to do it with a tiny DC inflator at the track too. Then once they are close to being out, you should be able to pull it out completely. Well at least thats my experience and hope it helps.
Automotive Monomaniac
Will it move at all? Has it moved a bit?
Try more air pressure, but expect it to really fly - so put wood and a towel around it.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Somewhere in the Midwest
You'll have to put the mating piston back in the caliper, then do as Derek suggested, block the the mating piston so there is more room for the stuck piston to come out further.
You may have to push the stuck piston into the caliper. Then do the above. Pushing it in will allow it to move out a little before it hits the spot when the seal and piston grab each other....repeat...push in, pressure, repeat. |
It is all the way in and has not moved at all...
Used compressed air, block of wood on all other three calipers, worked fine, this one piston is stuck in there. Is heating it an option - I know brake fluid is flamable...
Can you use a C-clamp (with a piece of plastic on it so you don't mar the piston) to move it either way? If it is really all the way seated, as it sounds, that won't work.
Was this piston frozen to begin with? Is it corroded?
You might try to rotate it with channel locks. Grab exposed (do not damage the OD of the piston) lip. It's most likely corroded and not sliding well on the seal.
Used a C clamp on the other free ones to hold them in, this one is all the way in and cannot grip it with anything.
Any thoughts on tapping in the center of it since it is a hollow piston to try and move it? Will this damage it?
The last thing you want is to mar the piston.
No no...take the clamp off the other one. Try to rotate the stuck one so you get it unstuck...do it w/o pressure...the piston is probably corroded and bitting into the seal...patience.
You might want to try some PBBlaster and let it soak in a little. It has a wicking action so it might put you over the edge. Definitely sounds corroded.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
Put the other piston partway back in, fill the caliper with water and close all the fluid exits (use the bleed screws). Then compress the one good piston (c clamp, vise, whatever). the other one will come out, hydraulic press principle.
I was in your shoes yesterday. First, thing we (my Dad was assisting me) tried to do was to get it to spin it just a bit. We used a channel lock...a large one. From there one person kept teh air pressure connected while the other pried on the piston head with a screwdriver or large gasket hook. The combined efforts popped it off but it still took a while. Patience adn good luck.
GeorgeK's idea is a really good one, wish I had known that when I went thru this. Otherwise PB blaster "bath" persuasion with C-clamp or channel locks and plenty of airpressure> IOf the pistons are caked with "gunk" I had great results with Googone and a kitchen (nylon) scouring pad.
Richard Lane 1978 911SC 1973 "Clean" RS clone |
Paper Member
I've sometimes had success hitting the caliper with a hammer behind the stuck piston with it under air pressure and soaked with penetrant. The shock or vibration seemed to loosen things a bit. Good luck.
Dave
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
You can push the piston all the way in and then have them glass beaded. This will eliminate the corrosion around the lip and it should pop out with all the other suggestions....pb blaster soak, in & out with air pressure a couple dozen times till it comes out!
Great suggestions guys. I really like Georgek's idea, I will try it as long as I can find a bolt to close the opening where the brake line attaches.
Cheers, Derek I will let you know if I get it!
Best of luck to you...
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Neil '73 911S targa |
