-   -   Sway Bar Bushing Question (http://forums.pelicanparts.com/porsche-911-technical-forum/225849-sway-bar-bushing-question.html)
KNS 06-11-2005 07:29 AM
I'm going to be changing out the swaybar bushings (along with a bunch of other suspension work) for new, stock rubber bushings. The Bentley manual says to use Contiflix lubricant on the new bushings. I'm sure this isn't a must-have. Any other similar (silacone-type) products out there that are just as good?
Thanks..
jtkkz 06-11-2005 07:38 AM
I use to owna bike shop, and remembered that grip shift company made a thick, sticky lube called (grip shift snot lube) you can probably get them at your local bike shop who carries them.
They actually work very well, I have used in all my past 911's sway bar bushings.
KNS 06-11-2005 08:49 AM
Thank you.
Anybody else using other products?
Nine9six 06-11-2005 09:15 AM
I was thinking of snorting some to relieve this nasty congestion...:D
Early_S_Man 06-11-2005 09:38 AM
Kurt,
As usual ... any of the Dow Corning 4, 111, or 112 silicone greases work well! TRW Sil-Glyd would work, too, but not my recommendation!
