-   -   My distributor rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/226001-my-distributor-rebuild.html)
mb911 06-12-2005 09:44 AM
Ok I have been thinking about doing this for a while as my car had advance issues and it missed so this is what it looked like after I completed a good dissasembly and cleaning and replacement of shims, advance retard module,rotor,cap, green signal wire, msd igniton wire lead ( I made), And bead blasting and clear coating the housing. Took about 1 hour start to finish and I must say it was very junked up before now it runs much smootherhttp://forums.pelicanparts.com/uploa...1118594271.jpg
Kurt B 06-12-2005 09:46 AM
Sure looks nice! Looks like it just came out of the factory..or is that a new on in the pic?
mb911 06-12-2005 09:54 AM
Thats the rebuilt one just installed this morning and timed etc. I wish the whol;e engine looked like thathttp://forums.pelicanparts.com/uploa...1118595228.jpg
mb911 06-13-2005 06:32 AM
bump for monday so all can see that it can be done
Par911 06-13-2005 06:38 AM
Nice work Ben, that looks very blingy! :cool:
Crowbob 06-13-2005 06:40 AM
Ben,
Very nice! Where did you get the new advance/retard module and how much did it cost?
Jim
mb911 06-13-2005 07:11 AM
40 bucks world pac
}{arlequin 06-13-2005 07:27 AM
that's nice Ben.
Any more pics of the "during" stage? What's the adv/retard module look like?
Did you have to recurve it?
My car misses and it's getting worse and worse and I think I should jump on that job pretty soon too.
mb911 06-13-2005 07:38 AM
Dave I left everything alone inside except for cleaning and reshimming. The springs were in tact and the bushings seemed ok. However I still have a miss that now Seams as though I have eliminated all ignition and I am going after fuel distributor. Tim handcock had a pic of them complety disassembled in his thread if you want to look at his search distributor rebuild.. As far as curving once I put it back together I check timing With and without advace and retard hooked up and followed the hayne manual specs and it fell right in there so It was fine. I would think however if you took it to a shop they could test it for you. The toughest thing about the project is to find a pin for the gear. I called pelican but it was back ordered so I went with the roll pin as most domestic cars are this way. I do however have the pin back ordered I think(paperwork did not show this from pelican) So when it comes in I will put that in..
Tim Hancock 06-13-2005 08:52 AM
Hi Ben, there is no "D" in Hancock ha ha!
Tim Hancock 06-13-2005 08:53 AM
Hi Ben, there is no "D" in Hancock ha ha! Your distributor looks brand new! Very nice!
}{arlequin 06-13-2005 08:58 AM
Tim, can't seem to find your thread on this. Any leads?
Tim Hancock 06-13-2005 09:04 AM
http://forums.pelicanparts.com/showthread.php?s=&threadid=181925&highlight=DIY+di stributor
This was my distributor repair Harlequin.
I try to put DIY on every thread that I post about something I think others may want to try so it is easier to search for again.
}{arlequin 06-13-2005 09:18 AM
that's a good idea Tim. My search terms were your name and distributor, but that came up w/ nothing other than this thread LOL
Great write up, thanks.
mb911 06-15-2005 12:50 PM
This bad boy is coming back apart to fit the springs better this weekend. I hope I can make this thing work properly
