-   -   Rotor and Cap question. (http://forums.pelicanparts.com/porsche-911-technical-forum/226278-rotor-cap-question.html)
nixter 06-13-2005 11:54 PM
I replaced my ignition wires on Saturday and WOW, what a difference! Better everything! Anyways... When I took off the rotor cap I noticed the six copper contacts and the rotor "blade" had a dark gray/black residue which I guess is caused by friction over the years. Everything still works fine but I can't help but think the contacts should be clean. Would fine grain sandpaper be ok?
Thanks,
nik.
rfuerst911sc 06-14-2005 03:06 AM
You can try that as a temp fix but for the price of a cap and rotor ( under $20.00 ) in my opinion you should just replace them. You can keep the set you have as a emergency spare. I recently had an ignition miss on my car and replaced the cap and rotor, the old set I took off had what you describe on the cap and rotor,other than that they looked fine.
Nine9six 06-14-2005 06:50 AM
If you can feel (with your fingernail) a step in the contacts of the cap or rotor, its time to replace.
nixter 06-14-2005 08:12 AM
Thanks!
Also, when I replaced the wires I didn't replace the wire that comes out of the center of the rotor cap and attaches to the cylinder shaped unit directly above the rotor because I could not figure out how to remove the wire from the cylinder end of things, it doesn't just pull out.
Thanks.
nik.
