Fuchs and 944t calipers
I am interested in purchasing Fuchs, 7 x16 and 8's or 9's to replace my 944t 7 and 8 Phone dials. I will be running these on my gt flared 914 3.0 turbo that has 944t calipers. Can I use the 911 Fuchs if I am able to use spacers. Will spacers give the rims clearance from the calipers or are there other reasons the 911 Fuchs wont work with the 944t brakes.
There are 2 versions of the 7x16 Fuchs, both have the same +23.3mm o/s. The 911 version will need a ~6-7mm spacer, the the 951 version will not. There will be no issue at the rear w/ either 911 +10,6mm 8s or 930 +15mm 9s
Because I am planning on using spacers, and have been with my other rims my options have been expanded, thanks Bill.
| All times are GMT -8. The time now is 03:13 PM. |
