Help! I can't get my shifter back in!!
Please kind Pelicans, I need some advice. I removed the shifter in my 87 Carrera to replace the bushings and clean and lube everything. I put the car into 4th as per the Bently manual , and the shifter came out with no drama. Now, wehn I tried to reinstall the lever there is not enough room to get it into the hole in the tunnel so I can insert the shift rod that goes toward the back of the car. Is there some trick for getting the shifter assembly back in? Help!! Please.
80 911SC Coupe, Grand Prix White- 3.2l twin plugged,Electromotive EFI w 46mm PMO throttle bodies, Fabspeed RSR headers/exhaust. 305whp. |
DP935 member
Its been along time since I installed one so the memory isnt good right now.
Here is a previous link that may help. http://www.pelicanbbs.com/posts/83116.htm
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
DP935 member
Here is a exploded view of G50 shifter mechanism also if you need it.
Need Exploded View of G50 Shifter Mechanism
Thanks kycarguy. I have the shifter back together just fine, I just cant get the shifter rod back far enough to slip the shifter mechanism in the hole in the floor.
80 911SC Coupe, Grand Prix White- 3.2l twin plugged,Electromotive EFI w 46mm PMO throttle bodies, Fabspeed RSR headers/exhaust. 305whp. Last edited by racerdoc911; 06-16-2005 at 05:39 PM.. |
Turgid Member
I just did this a year ago when my china-hat bushing crumbled to pieces. I seem to remember having to put the rod in first, by itself. You have to rotate it in the channel to get it to slide all the way back and clear the cutout, then attach the rest of the stuff.
Nice and smoothe when its all back together...
'87 Carrera "Man who go through airport turnstile sideways going to Bangkok" |
