-   -   Name the part?? (http://forums.pelicanparts.com/porsche-911-technical-forum/226798-name-part.html)
Kroggers 06-17-2005 12:18 AM
Name the part??
Has anyone seen these before? I was told that it is a RUF, but can not find any part numbers :( Will this fit the normal (stock) heat exchangers that I have on my sc?
http://forums.pelicanparts.com/uploa...1118992685.jpg
Steve@Rennsport 06-17-2005 12:56 AM
Hi Paul:
Do I get a prize????? :) :)
Thats a 930 dual outlet muffler. From that view, I cannot tell if its a Ruf, or a Borla but it only fits a Turbo.
Kroggers 06-17-2005 01:05 AM
So, no chance of it fitting my sc then :(
trak ratt 06-17-2005 04:41 AM
You might be able to fab a connector piece between you SC’s Cat/test pipe and the muffler inlet. The muffler itself should mount as your SC’s does. Second outlet would need a valance mod. Might want to remove the rear valance until you get the muffler fitted. No sense moding the valance if the connector pipe can’t be fabed up..
Steve@Rennsport 06-17-2005 09:25 AM
Nossir.
Even if you did manage to mate them up, its a big waste of time & money since its not tuned for the N/A SC engine.
