likes to left foot brake.
Photos of Turbo+1 Steel flares.
Brandon's wide body is getting wider.
RS fenders limiting your tire sizes? Turbo flare to tire clearances just a little tight? I took these photos during a couple visits to Axiom Motor Sports in Los Angeles. You can have more tire and a lower ride with a steel flare. Take a stock turbo flare....Widen it a little over an inch... Metal work it.... Finish bumper to match then skim coat and block sand. 3.6 with 46 webers..... ![]() No one will know untill you park next to a normal turbo body. My 911 project got a little more of the same.
Adrenaline Junkie
Okay, now that is cheating.
Wow..nice work...you will be able to run a pretty massive tire in there...
Yasin
Ole Skool - wouldn't have it any other way |
So, What tire & wheel size ARE you running?
SMD |
It's Brandon's car not mine.
I'm not sure I think he has 17 inch rims, maybe 335/35/17s?
