-   -   Steering wheel wobble. help needed (http://forums.pelicanparts.com/porsche-911-technical-forum/226861-steering-wheel-wobble-help-needed.html)
al74911s 06-17-2005 10:23 AM
It's been a while since I last posted. I removed the steering wheel and tach from my car a couple of days ago and found there are a couple of loose bolts that are supposed to keep the steering column in place. Attached to that, under the steering column, is a sort of clamp. What I need to know is what type of bolt should be found there. What I have are a couple of bolts with round heads. Do I need a special tool to tighten them?
Thanks in advanced for your help Pelicantes!!!
