svonkampen's Avatar
Throttle Cable Snapped....on my '68 911L....i think
Hey,
Throttle Cable Snapped....on my '68 911L....i think....
Just towed her back to my place......As far as I can tell from feeling around down there....the rod connecting the gas pedal is still connected but i don't know....
I am a useless wrench...but I'll give it a shot...
suggestions?
SvK
1996 993
1968 911L 3.0 Carb'd.....(sold)
"I don't even know enough to know that I don't know."
Old 06-18-2005, 12:24 PM
B D B D is offline
B D's Avatar
What happens if some one pushes on the gas pedal does the linkage on the carbs move? Check all the linkage to start, there are a few connections in the engine compartment just remove the air box to check those. The next connection to check would be under the car left rear by the trans and brake line. Good luck it's a simple system.
68 911L
Old 06-18-2005, 12:33 PM
svonkampen's Avatar
Ok....
the two push-rods...i think that is what they are called are properely connected, they haven't jumped off.....soooo i think my pedal is fine......I'm thinking my cable has snapped.....
SvK
SvK
1996 993
Old 06-18-2005, 12:34 PM
svonkampen's Avatar
BD my linkage is the culprit.......what page in the haynes manual?
do you know.....trying to find the stuff under the car!!!
thanx,
SvK
(god i'm useless hehehehe)
SvK
1996 993
Old 06-18-2005, 12:39 PM
svonkampen's Avatar
I'm looking at Chap2 Fuel&Exhaust sytems............found Accelerator Pedal stuff....but can't find anything regarding the linkage.
SvK
SvK
1996 993
Old 06-18-2005, 12:41 PM
B D B D is offline
B D's Avatar
There are also two connections behind the linkage to the carbs follow the rod back. The connection is by the left carb and up against the firewall. You will see a hole there where the rod comes up from below. You need a helper to diagnose this to push on the pedal while you take a look around.
68 911L
Old 06-18-2005, 12:42 PM
B D B D is offline
B D's Avatar
Not sure about Haynes for this, they cover so many years and use few good SWB diagrams. Check the linkage in the left rear, jack the rear up first.
68 911L
Old 06-18-2005, 12:44 PM
svonkampen's Avatar
right....
thanx
svK
SvK
1996 993
Old 06-18-2005, 12:45 PM
B D B D is offline
B D's Avatar
Check this thread for the daigram, part #18 is what you will see in the left rear. It goes up in to the engine compartment.
68 911L
Old 06-18-2005, 12:47 PM
B D B D is offline
B D's Avatar
Sorry here's the thread: Bolt sizes, clutch & Throttle adjustment Q's
68 911L
Old 06-18-2005, 12:48 PM
svonkampen's Avatar
BD ....urock
Checked underneath the car part "18" snapped !!!!
At least it is an easy fix!
btw: my car goes to TRE on monday for a new engine anyway......so it don't matter
SvK
SvK
1996 993
Old 06-18-2005, 01:08 PM
svonkampen's Avatar
OK what is the name of part 18?.......
Wayne you there?
SvK
SvK
1996 993
Old 06-18-2005, 01:34 PM
Grady Clay's Avatar
SvK,
There isn’t a cable; it is almost all rods and ball-socket linkage.
First check that all the linkage is connected. The links are:
Push rod from accelerator pedal to front bell-crank.
Pull rod at front bell-crank.
The infamous cushion alongside the transmission nose piece.
Links at the transmission bell-crank.
Pull rod between transmission bell crank and engine bell-crank.
Pull rod between engine bell-crank and carb cross shaft.
The two down links to the carburetors.
The most likely cause is the rubber cushion that is in the linkage
between the bell-crank at the pedal assembly and the bell-crank
at the side of the transmission. The cushion is located alongside
the nose of the transmission, just forward of the transmission
mount. The original part was two metal discs connected by the
rubber cushion in tension. When it fails there isn’t any
connection to the engine. You can do a temporary fix with a coat
hanger wire. The replacement part has a metal safety cover that
allows some throttle movement when the rubber fails.
Here is where the cushion is located (red arrow). If the cushion
is broken, you can pop the ball off at the transmission bell-crank
(green arrow) and pull the piece out to work on that half. You
will need to push forward the rubber bellows to unscrew the
front end of the cushion.
Occasionally the link at the transmission bell-crank wears through
(blue arrow). Check that also.
(C) Dr. Ing. h.c. F. Porsche A.G.
Here is the replacement cushion:
The root cause of this, other than an old rubber part, is the
accelerator stop may be adjusted too far down. This stresses
the cushion when you are at full throttle. It should be adjusted
so when you push reasonably hard, the throttles are just full
open. Of course the floor board must be in good condition.
Best,
Grady
svonkampen's Avatar
Grady i found the problem....it is part 18 that snapped.....see link above by BD....
i need to know the name of this part....
thanx,
SvK
PS
grady u are always so helpful
SvK
1996 993
Old 06-18-2005, 01:38 PM
Grady Clay's Avatar
Here is an illustration of the linkage from the engine forward.
The accelerator cushion is #10 (arrow).
This is the early style without the tin cover.
Best,
Grady
Old 06-18-2005, 01:59 PM
Grady Clay's Avatar
#18 is “Throttle linkage, rear” 901.423.026.03. You usually can repair the damaged/worn part.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 06-18-2005, 02:05 PM
svonkampen's Avatar
Thanx grady.......mine split at the ring/loopy bit....
How can I fix this?
SvK
SvK
1996 993
Old 06-18-2005, 02:08 PM
svonkampen's Avatar
80 frriiggggiiinnnn $ ?????????
please
SvK
SvK
1996 993
Old 06-18-2005, 02:10 PM
Grady Clay's Avatar
SvK,
The “ring/loopy bit” serves an important function. As the engine moves forward slightly it can slip and not add gas, it can only reduce the throttle opening. It also allows you to check for full throttle at the carbs while actuating the linkage only as far forward as the “ring/loopy bit”. To check for full throttle you need to actuate the accelerator pedal and adjust the stop.
Repair:
Probably the connection at the transmission bell-crank is equally worn and in need of repair. The best solution is to find some good used parts. You are going to want to replace the plastic bushings at the transmission bell-crank with new “while you are there.” Use this oppertunity to inspect the cushion. Even the updated part can have internal rubber failure that is difficult to detect.
Fixing the worn parts is difficult at best. I have seen some real Rube Goldberg attempts. The important thing is to not defeat the slip ability in the linkage. Put your creative hat on and post your solution.
Everyone needs to clean and grease that linkage spot at regular service; like oil change.
Best,
Grady
Old 06-18-2005, 05:19 PM
304065's Avatar
I just cleaned and lubricated mine tonight (my linkage that is) and found that some PO had omitted to include the cushion! And I just got through replacing the one on the '71. . .
'66 911 #304065 Irischgruen
Ex-'88 Carrera (Sold 3/29/02)
Old 06-18-2005, 06:33 PM
