Somatic Negative Optimist
Gunter's Avatar
Question Are early '78-79 US intakes the same as Euro intakes?
For 911's: On an early '78-'79 US intake, the airbox, FD, bigger intake runners, etc. are different from the later versions with Lambda.
Are the Euro intake systems the same as the early US system?
Example: Would a '81 Euro have the same intake system as an early '78-'79 US?
Thank you.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-26-2005, 06:14 AM
Oh Haha's Avatar
Geez, that was fast!
Pacific Blue
Wayne
Old 06-26-2005, 06:15 AM
Gunter's Avatar
Anyone?
Old 06-27-2005, 07:43 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
If there is anyway I can tell from looking on the outside of my engine I would be happy to help.
1981 SC ROW Coupe
Old 06-27-2005, 08:58 AM
Gunter's Avatar
Thanks. Yes, you can help. Measure the outside dia. of your intake runners; if they are 47.5 mm, the are the same as the early US intake runners.
But I am not sure if ROW are the same as Euros.
Old 06-27-2005, 09:32 AM
drag racing the short bus
dd74's Avatar
I think the '80-'83 intakes are the same size for both ROW and U.S. CIS systems. The '78-'79 intakes were largest whether ROW or U.S.
ROW should be the same as Euros. The main difference with CIS 3-liter engines between the U.S. and ROW engines lies in the higher compression of the Euro motors. In 1980, compression for the Euro motor was bumped up to 8.6:1, then in '81-'83, it was bumped up again to 9.8:1. Factory timing for the Euro motors might have also been advanced over the U.S. versions, giving them the higher horsepower they enjoy.
Old 06-27-2005, 10:26 AM
Go Speedracer, go!
I'll see what I can come up with when I get home from work. What about a part number or casting number on the intake runners. I seem to remember someone asking for that a while ago when trying to find the same information.
1981 SC ROW Coupe
Old 06-27-2005, 10:35 AM
Gunter's Avatar
Thanks dd74 and SpeedracerIndy.
Easiest way is to measure them; the early US intakes are noticably larger (~47.5mm), the later '80-'83 US with the Lambda system had smaller intake runners by about 5mm.
Old 06-27-2005, 11:15 AM
