Kevin Stewart's Avatar
Does a 3.6 have a pcv
My 1993 3.6 seems to be building pressure, is the a pcv valve,???? Kevin
Old 06-21-2005, 11:09 AM
Bill Verburg's Avatar
Sort of, a dry sump will generate a partial vacuum in the crankcase. This serves the same purpose as a PVC.
It is common practice to add another 1 way valve to further enhance the cc vac. the goal a few extra hp.
It is a factory piece on the 996 Cups
Bill Verburg
Old 06-21-2005, 01:07 PM
kang's Avatar
I believe there is a vent line from the oil tank to the intake, just below the throttle body. This vacuum sucks oil fumes into the intake. I don't think there is a traditional "PCV Valve" though.
Downshift
Old 06-21-2005, 01:11 PM
That too
Bill Verburg
Old 06-21-2005, 01:13 PM
kang's Avatar
Bill, can you describe this 1 way valve a bit more? Where does it go? The vent line I described?
Old 06-21-2005, 01:49 PM
Here is a pic of the valve
It goes on the cc breather, which is normally a neutral or 2 way operation. it is a one way valve that allows pressure pulses out of the cc but does not allow regression of the pulses.
The bigger the pistons the more air is moved around in the cc, 3.6 has a bit of a problem, 3.8 much more so. These types of devices enhance the natural dry sump induced cc vacuum. Very common on race motors w/ big pistons, and high perf Harleys & Ducatis of course.
there are other methiods of generating cc vac, from mech pumps to the exhaust driven method used by the nasty car guys
Bill Verburg
Old 06-21-2005, 02:29 PM
kang's Avatar
Interesting. How would you add this 996 part to a 3.6?
Downshift
Old 06-21-2005, 02:51 PM
Dunno, just looking into it now, there are several options for the valve, it is a low tech item.
Bill Verburg
Old 06-21-2005, 02:58 PM
