-   -   Another successful Ducktail conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/227279-another-successful-ducktail-conversion.html)
drl911 06-20-2005 10:27 AM
Just a few pictures of the new FG Ducktail installed. The overall fit could have been better, but I am generally pleased. BTW - It is close to 25lbs lighter than the stock Carrera whale tail. I even made my own latch assembly from aluminum stock by reverse engineering the original pieces.
Dan
http://forums.pelicanparts.com/uploa...1119287733.jpg http://forums.pelicanparts.com/uploa...1119287764.jpg http://forums.pelicanparts.com/uploa...1119287804.jpg
911SCfanatic 06-20-2005 10:29 AM
Dumb question: does the ducktail use the stock engine grill?
thrown_hammer 06-20-2005 10:29 AM
We must see the lightweight latch you made! Oh and nice car. (Love the exhaust)
niner11 06-20-2005 10:32 AM
Nice looking car with or without the duck. Do you know who made the tail and what color was it before the tail was prepped and painted.
There has been some discussion as to who makes most of the tails out there and sells them wholesale. Some fit a lot better than others. Thanks, Chuck
jbrinkley 06-20-2005 10:36 AM
can I ask which, and who's bumpers and tail you bought? I'm going for the same look
thanks
FrayAdjacent911 06-20-2005 10:39 AM
I gotta say, the tail looks good. I like it on pretty much any 911. I saw a RUF 996 that had a ducktail type decklid on it, and I liked it.
drl911 06-20-2005 10:45 AM
It uses the "stock" grill from a "no frills" engine lid, but not the grill from original Carrera whale tail.
Dan
Argeo 06-20-2005 10:46 AM
Looks great. Wish mine lined up as well.
drl911 06-20-2005 10:51 AM
thanks
The Ducktail was an ebay purchase and I have reason to believe it is a MASHAW (cannot confirm). The rear bumper is a f/g IROC from the PO. The front bumper is stock steel without the rubber bellows (I made the front bellow replacements myself) or front rubber strip across the front face. The rubber smile is still installed.
Dan
drl911 06-20-2005 10:56 AM
The exhaust is aftermarket headers (brand unknown by me) with "tuneable" SuperTrapp mufflers. I really like the SuperTrapps because if I am going on a long trip I can remove the plates for a nice quite ride or when playing at the local drag strip, etc... I can gut the system in 2 minutes and let her breathe!!!:D
Dan
fastpat 06-20-2005 11:59 AM
I recently saw an original Carrera with a duck tail, and I was surprised by the fit and finish, plainly stated, it was rough. I asked the owner about it, he said the factory knew what the purpose of the car was, and when they made the duck out of a standard engine lid, the fiberglass guy they used was, shall we say, less than perfect in his layups.
I suspect that most ducks made today are superior in looks to the original by some level, more by some than others; but since most of us want a fit similar to or exactly like the stock lid, we're demanding more than Porsche did 30 years ago.
That's, over all, not a bad thing.:D
vash 06-20-2005 02:34 PM
drl, is your AC gone?
your car looks fantastic, and made me scramble for alf's duck.
bigchillcar 06-20-2005 03:02 PM
dan,
i'm curious about your exhaust..forgive my ignorance, but is it what they refer to as a 'restricted exhaust'? is it for sound? if it gives the car a deeper sound, can this mod be performed to a '74 with the stock (very nice) exhaust? i love the throaty sound..but with a cis car do you our anyone else know of simple mods that can be done to increase this?
ryan
fastpat 06-20-2005 09:00 PM
Those appear to be SuperTrapp™ mufflers. If so, they have removable plates or discs that can vary the sound emitted. They've pretty much always been very controversial at to whether they work as advertised. That is to say, you remove (if memory serves) plates to reduce sound, but removing plates reduces flow. The controversy came in when you have removed enough plates to not annoy the copshttp://www.pelicanparts.com/support/smileys/wat.gif, does your engine produce the same power it would if you had a well engineered, but more conventional exhaust system.:confused:
Personally, I can't say. I've never installed them, and have never run tests on a car with them installed. http://www.pelicanparts.com/support/smileys/vuur.gif
