High Speed stability issues - diagnostics?
I've had my Porsche for three years now. It has always been rock solid at speed (up to nearly 160 mph)... until recently.
As of the past month or two, I've noticed at speeds over 80 mph, the car is a bit skittish, darty maybe. When I apply the brakes, the car even seems to get a bit more unsettled. Yesterday, I had it at about 150 mph (in the California desert) and it was downright scary - really had me concerned as it wasn't stable at all. I lifted off the gas and coasted until well below 100 before I applied the brakes. The car has new shocks on all four corners, new front bearings (they are tight, I just checked), good front tires, brand-new rear tires, stock aerodynamics front and rear... I don't think it is aerodynamics. I don't think it is street tires as it was acting a bit funny on the R-compound rubber when I had it at the track a few weeks ago. The alignment was just done about two months ago - and it tracks perfectly straight - but it is still suspect. What do you all think? Alignment? Bushings (I think they are original)? Other? |
What about aerodynamics? At those speeds, anything passing under the car is going to create lift.
.... and holy smokes! Don't get caught driving those speeds. You'd probably lose the car and your freedom. |
I rule out aerodynamics as the car has the stock front chin and rear spoilers both intact and unmodified. The car is also at Euro ride height. It doesn't feel like it is lifting - just unstable.
sounds like to much in the back
not enough pressure in the front high speeds give you front lift when you apply brakes, the weight tranfers brutally and gives the car the shakes... with your new shocks and alignment , possibly it has less rake now front a bit higher, the back a bit lower... just one idea... |
I am thinking the car needs new suspension bushings. Does this make sense? Would old bushings "give" under stress (at higher speeds/loads) and braking would compress them even more - both distorting the suspension settings causing my instability? |
Hows your alignment? Toe settings?
My tires are different too... would that make a difference?
Front - Yokohama AVS Intermediates Rear - Yokohama AVS Sports I don't seem to remember if the stability issue existed before the tire change... |
I'd say yes due to differences in tread pattern, possible differences in sidewalls, etc...
:( Crap.
My wrench thinks the tires are also the issue, followed by alignment settings. Bushings are probably not the issue. I am not in the mood to dump another $320 on front tires when the existing tires are still good. Really sucks. |
Now's your change so burn some rubber and wear those puppies out :) You could probably sell them in the classifieds...
Your problem is your toe setting.
You have original suspension bushings, and your wrench thinks that's not the cause?
My "wrench" - the guy who actually physically will work on my car - hasn't been asked. My "wrench" (who I referred to) - the mechanic who I have known for years but lives too far to touch my car - says it's not the bushings. He has a 951 (944 turbo) with the same issue, different tires on each end causing instability. I'd much rather drop $150 in alignment and parts for bushings than spend $350 on new front tires. There is a thread somewhere about good alignment shops in the area. I need to search and find it. |
I'd try Tyson at TRE first, if they do full alignments, then try
Johnson Alignment in Torrance, talk to Steve Alarcon. |
If your rear tires are brand new, and the fronts aren't, then the car will be squirrelly until the rears are scrubbed-in and heat cycled.
Basically, the rear tires are brand new squishy sidewalls, with tall tread blocks on them, and the squirm around more than the fronts. This isn't such an issue if you buy tires with the N rating on the sidewall. These denote tires that Porsche has spec'd as being compatible with their cars. They have a stiffer sidewall. |
OK. This problem is obviously not the aerodynamics, as they are the same a s always. Does it on two different sets of tires. You have relatively new shocks and alignment...do the tires wear differently L -R, are they scalloped or tread worn funny?
I would at the very least look at the bushings, ball joints and tie rods, and check the rack. Are your tires balanced (maybe you lost some weights)? My limited knowledge of this is that once you introduce any sort of bind into the suspension, it gets squirrely. Are your alignment and CB numbers repeatable? Are you getting vibration back into the steering column, or just a bit of loss of control? |
I would check alignment first.
Tyson:
Where would one find this "N" rating? Is it marked on the sidewall somewhere? Pat |
All great advice.
1. I like Tyson's comment about the brand-new rear tires. They have about 80 miles on them, and they had not been heat cycled. 2. Put the car in the air and check all visible bushings/suspension. 3. Have the alignment checked/re-done 4. If all else fails, buy new front tires. |
Get it up on the rack and start shaking things...tie rods, bushings or tires are my guess. When was the last time you had it on scales and checked the balance?
jack it up and check your rear wheels for play.....your situation sounds like mine when my left rear wheel bearing went bad.
I still believe the problem you are describing has to do with toe settings. Under braking these settings are amplified greatly by the transfer in wieght. On occassion I have the same problem with the car pictured below and we go to the toe settings and it goes from scary under braking to rock solid and I can make the thing do cartwheels if I want to:)
Granted it is a full blow race car but the geometry involved can exist on both carsand your description of the sensation under braking is right on. http://img.photobucket.com/albums/v6...Race/PocTH.jpg |
my toe went way out of spec while the car slept in the winter. don't know why, or what caused it. my alignment guy is really good, and I have the before and after numbers.
after 1000mi this spring with really skittish steering (noticeable at 70-80mph) it wore my very new front yoko es100's bald on the inside edges. that's when I discovered the problem. sadly my tires only have 4000 miles on them, & now that I've had it aligned back into spec, they really suck in the rain. so, save your tires!!! get your alignment checked asap. |
You want the same N number front and rear, or the higher number in the rear if they are different. It's O.K. to run non N-rated tires, but you may end up with this problem of squirrely, tail happy handling until they break in. |
I just ran out to the car and crawled under with a flashlight. The inside edges of my fronts are wearing very rapidly! Two months ago, they were fine. Yikes! I need to check the alignment ASAP. |
I'll tenth. Have the toe checked. I have the toe on my car set at 1/16 for AX turn in. Its pretty twitchy. At high speed it doesn't take much to move the car around.
But it tracks prefectly straight down the road. Just food for thought. Good Luck. |
Might be a camber issue too.
"The vehicle may feel more "nervous" and become more susceptible to tramlining. Excessive camber will also reduce the available straight-line grip required for rapid acceleration and hard stops." http://www.tirerack.com/tires/tiret...e.jsp?techid=4. Cheers, Joe |
