Banned
speeder's Avatar
'89 Carrera front hub to rotor torque please?
Does anyone have a Bentley manual or a factory spec book handy that can provide this spec? Also, the correct tightening procedure for the big center (spindle) nut? Thanks a bunch, I'm sure it's on this board somewhere but I don't want to throw my laptop through the wall trying to use the search fuunction here.
Old 06-20-2005, 03:54 PM
Bill Verburg's Avatar
23 nm
Bill Verburg
Old 06-20-2005, 03:59 PM
makaio's Avatar
By spindle nut do you mean the wheel bearing retaining nut? If so, you tighten it down to where you can just budge the washer back and forth on the axle with the edge of a flat head screw driver.
Old 06-20-2005, 04:33 PM
Banned
speeder's Avatar
Thanks, Bill. How about the spindle nut? Hand tight, or tighten/loosen/etc.?
Old 06-20-2005, 04:34 PM
While rotating the disk slowly tighten the the lock nut untill the the thrust washer can barely be moved back and forth with light pressure. Tighten the clamping screw to 15 nm
Bill Verburg
Old 06-20-2005, 05:31 PM
