-   -   toe and camber questions for 930. (http://forums.pelicanparts.com/porsche-911-technical-forum/227430-toe-camber-questions-930-a.html)
look 171 06-21-2005 01:38 AM
A bit confused after reading some of the old threads on the subject. Where do you guys set your alignment? neg 1 degree up front and factory toe spec? I have a 88 930. Are the specs same as any 911? It is a street car. The factory calls for neg. 1/2 a degree in front, I think? Any one? I have 245 40 17" tires up front. I don't think it should make a difference.
Jeff
look 171 06-21-2005 07:44 PM
Bump. Anyone?
Jack Olsen 06-21-2005 08:27 PM
What's the car used for?
look 171 06-21-2005 10:05 PM
Jack, its a street car. Mostly canyons and such; some high speed out in the desert at times. Thanks
Jeff
