Thunder Punk's Avatar
Silicon under door sill plates.....Best removal method?
I folks. I decided to replace my door sill plates today as the old ones looked a little ratty. The previous owner of the car used silicone sealer under the passenger side plate. I'm having extreme difficulty removing the silicon.
I've used WD-40 and mineral spirits to try and soften it up a bit but it doesn't help. So far I've had my best results using a plastic paint scraper but the progress is extremely slow and labor intensive. I tried very sharp metal scraper but that didn't work any better that the plastic one. I also tried a straight razor. It digs into the paint.
Do any of you know any tricks to get this stuff removed without damaging the paint underneath? I need a nice smooth and clean surface so the new sill plate tape will adhere.
Old 06-21-2005, 08:11 PM
Registered abUser
TerryH's Avatar
Razor sharp plastic scraper and then mineral spirits. I know of no easy way to remove silicone.
'81 911SC Coupe SOLD
Old 06-21-2005, 08:28 PM
Super Moderator
cstreit's Avatar
Unfortunately there aren't any chemical methods to remove silicone that won't also damage your paint. Elbow grease is the only way.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-21-2005, 09:21 PM
That's what I figured. Thanks for the replies.
Old 06-22-2005, 06:46 AM
KCinBR's Avatar
Just did the same thing about a month ago.....the silicone is a real pain to get off. I just rubbed with my fingers untill it came loose. I tried solvents without success, I was afraid of removing the paint also.
There's no magic solution just keep rubbing it will come off.[U]
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 06-23-2005, 03:49 AM
Send a message via AIM to Dionikes Send a message via Yahoo to Dionikes
Try 3M general adhesive remover. That is what I used. It is not a great advantage but it seemed to melt some of it. It also does a great job breaking down weather stip glue.
That silicone crap is nasty...good luck
A blog on my '87 Targa
http://porsched.blogspot.com/
Other ride:
'03 BMW 330Ci
Old 06-23-2005, 06:31 AM
Thanks...My neighbor behind me works on Mercedes and recommended the 3M stuff too. I'll give it a shot. I've got to remove the weather strip adhesive too so I'll need to get some for that anyway.
Old 06-23-2005, 08:34 AM
Registered abUser
TerryH's Avatar
This is what I use to scrape silicone off painted surfaces. It's called a windshield stick or plastic knife. Used mostly by windshield installers. Very stiff and very sharp on one end.
Free plug for the Porsche bibles too.
Old 06-23-2005, 09:49 AM
scottb's Avatar
Would a heat gun help loosen it up a bit?
1984 Targa
Old 06-23-2005, 10:16 AM
Probably not. I think the biggest problem is that the silicon is old and semi dried up so it breaks off in little pieces if you pull too hard. But, it's still resilient enough to retain it's adhesion. If it were newer I may have been able to heat it up and pull very gently to remove it in bigger pieces.
That scraper looks like the ticket. Where might I find one of those? And my copy of Wayne's book should be here any day.
Well, actually it just arrived as I was typing this. Cool!
Old 06-23-2005, 11:02 AM
Goof off. Worked on mine with zero paint damage.
Marc
1971 T Targa
Old 06-23-2005, 12:09 PM
Ah Hah. Goof Off. Now that's a name I hadn't heard in a long, long time. Will give that a go too!
Old 06-23-2005, 01:11 PM
Registered abUser
TerryH's Avatar
To locate a windsheild stick, try your local auto glass replacement company. I buy mine from the manufacturer a dozen+ at a time.
Old 06-23-2005, 04:40 PM
bigchillcar's Avatar
'goo be gone'..same thing as goof-off i think. removes sticky tape backing like magic..some kind of volatile solvent. works for many things.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-23-2005, 05:06 PM
Eric Coffey's Avatar
PPG DX330.
Old 06-23-2005, 07:36 PM
Well, I managed to get it all off of the passenger side and moved to the driver's side tonigh. The dealer evidently used some kind of general purpose white adhesive. What a mess.
So, I used wd-40 on the adhesive and it took it right off. (Little trick learned from removing decal residue from my sport bikes.)
Then I applied some rubbing alcohol to remove the oily residue from the WD-40 and to my surprise that made short work of the silicone that was beneath the adhesive. So both sides are ready to go. Just need to install my weather stripping now.
Thanks fellas.
Old 06-23-2005, 07:41 PM
