PeteBrown's Avatar
Fat pig Carrera brakes
FYI - I had a great week-end two weeks ago at NASA's HPDE at Beaverun. In the past I have had trouble keeping my brake fluid from boiling using ATE Super Blue and Hawk HPS Plus pads. Well, at Beaverun I used Motul RBF600 fluid with a new set of Porterfield R-4's and had better results. The Porterfields bite very well with little fad when hot and the Motul fluid never boiled. My brake pedal remained firm all week-end with ambient temperatures in the mid to high 80's all week-end. Now Beaverun is not the toughest track on brakes but it's relatively short at 1.6 miles and has two straights.
My '87 has stock brakes with the backing shields removed and Noel's 993 diverters up front. So before you buy that $2,000 930 brake upgrade, try Motul over Super Blue.
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 06-24-2005, 12:56 PM
efhughes3's Avatar
I switched recently too. The Motul does seem better. I ordered a set of 993 front calipers today, which will go on soon with 309mm rotors. That and a rebuild of my stock rears, and I can't wait to track them in October!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 06-24-2005, 02:44 PM
Motul RBF600 has a slightly higher boiling point rating than ATE.
http://www.seinesystems.com/BrakeFluids.htm
Sherwood
Old 06-24-2005, 02:49 PM
Me like track days
Craig 930 RS's Avatar
It is better.
My customers report less staining (ATE Blue will stain EVERYTHING blue) and better 'luck' regarding fluid boiling with smaller brakes at the track.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-24-2005, 02:52 PM
Jeff Alton's Avatar
The blue is okay for street, use the motul on the track. I even notice a difference with the new brembos....
Jeff
www.turn3autosport.com
Old 06-24-2005, 08:20 PM
