-   -   Compression Test results. (http://forums.pelicanparts.com/porsche-911-technical-forum/227672-compression-test-results.html)
Carl83911 06-22-2005 12:57 PM
Jimmy from MobileWrks came over last Saturday to perform a compression test on my 83 911. Test results show the following:
#1 = 165
#2 = 164
#3 = 165
#4 = 164
#5 = 165
#6 = 164
Just to compare to other SC's, can you show me what your compression readings were on your car? What is the ideal result? My friends 1980 SC measured at around 123-128.
cbeers 06-22-2005 01:06 PM
WOW Carl,
Those are as close as can be! I don't know what they SHOULD read, but I do know that having them so close is a good thing.
Unless your whole engine is falling apart at exactly the same rate ;)
Looks great!
-Chris
Jeff Alton 06-22-2005 01:30 PM
Those are just fine.
Jeff
laddsc 06-22-2005 01:36 PM
My numbers on my 85 RoW came in 4 months ago between 190 and 200. However my compression is higher in the RoW and that might make the difference. Not sure. Little variation is good, as cbeers said.
dandrews64 06-22-2005 01:44 PM
140K miles
1: 170/5%
2: 175/4%
3: They can't get the plug out !!!!
4: 175/4%
5: 173/5%
6: 170/5%
Carl83911 06-22-2005 01:50 PM
Originally posted by dandrews64
140K miles
1: 170/5%
2: 175/4%
4: 175/4%
5: 173/5%
6: 170/5%
____
The %ages, Are these Leak down test results?
dandrews64 06-22-2005 01:52 PM
Yes they are. Just had it done this week.
anthony 06-22-2005 04:47 PM
When I had my '81 SC PPI'd it came in at 165psi accross the board. The mechanic said "good as new".
cbeers 06-22-2005 05:05 PM
Doug,
Stuck plug? For how long? It has to come out sometime right?
Also, I see you have a thumper in your stable. Do you ride often? Where?
You can PM or email so we don't highjack Carl's thread :)
cbeers@appsig.com
-Chris
MobileWrks 07-19-2005 10:20 PM
"doug" i can get it out.... the longer you wait, worse your car will rumn.. like bitting a apple with one front tooth,...LOL
drsimonwong 07-20-2005 12:14 AM
I think there is much variation in the individual gauges in individual shops so it's the variation between each cyclinder that is critical. Given your figures are within 1 point of each other it reads perfectly!
On that note mine are all between 145 and 150. Comments?
Simon
darkbeer 07-20-2005 01:06 AM
150 thru 155...
'75 2.7 CIS with unknown mileage & very complete rebuild done in '89 with "euro" P&C's...( I fixed the odo after I bought the car last year, but the orig. owner had not...for 12 years....DOH!!!)
