Ride Height Adjustment
Does the engine and transaxle have to be in the car to adjust my spring plates and front sway bar for ride height?
Andrew Gruppe B #055 78 911SC 74 914 2.0 02 C230K Kompressor 73 VW Beetle AutoStick 02 F250 4X4 (Parts Hauler) 03 Kia Sorento (Wife's DD) |
Somewhere in the Midwest
Yes.
Well, technically, no, if you knew the exact weight of the car with drivetrain installed. But unless you have accurately weighed it very recently, don't try to set the ride height until all the bits are back in.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I guess after reading my question, I realized it was pretty stupid! What I MEANT to say, was.... When I have my dirvetrain out, it will easier to get the spring plate bolts. I plan on getting them at least loosend during that time.
My real question...Can I make minor adjustments on both spring plates to start the process as far as ride height, then after the drivetrain is back in, do the final adjustments. I am unclear on what may happen when making an adjustment without proper load in th car.
Theoretically you could adjust ride height if you temporarily install weight equivalent to the drivetrain mass. Maybe this could be a new product I could offer: 600 lbs of dead weight in 100 lb increments; offer used bowling balls for precise weight substitution. UPS charges would be deadly though.
Sherwood |
