Will a front a/c condenser from an 84 fit an 82?
Just like the title says, I have a front a/c condenser for sale and someone with an 82 wants to buy it, but neither of us are sure if it will fit. Thanks,
Tommy |
Nope
The fittings for an 82 are flared, the fitting for 84 are o-rings. You can buy some adapters to convert the o-ring fitting to flare and than it will be able to connect up to the old hose, but if the owner is upgrading the hose he should consider o-ring fitting. |
What about the guard bar? Will the 84 fit an 82?
Ruf, this one is from an '83SC. The fittings look flared not O-ring, correct? So I think it will fit my '82 (Platinum Metallic, of course....)
Thanks http://forums.pelicanparts.com/uploa...1119645010.jpg |
83 will be a flare fitting so it will fit a 82.
| All times are GMT -8. The time now is 06:26 AM. |
