rudy's Avatar
Send a message via AIM to rudy Send a message via Yahoo to rudy
Question about 930 shifter rod
Is the shifter rod the same on a 915 and a 930? I know the 930 shifter lever sits lower than the 915. Is the bracket for the rod bushing the same also? I read on some 930 trans swaps people say you need to change shifter but don't say anything about the rod. Thanks, Mark
Old 07-05-2005, 09:27 PM
Mark,
The main shift tube in the tunnel is the same for a 915 and 930 equipped chassis.
Regards
Hayden
Old 07-06-2005, 09:34 AM
rudy's Avatar
What about the bracket for the bushing. Does it set the tube lower since the shift lever is longer? I need to figure this out since I put the 930 trans in my car. Thanks, Mark
Old 07-06-2005, 02:53 PM
Mark,
PET shows an alternate part # for the "L"shaped bracket. Whether or not it is dimensionally different to the 915 part # I am not sure....
edit:
Plus that same 930 part # is used for '83 and later SC, so my assumption would be that the bracket holds the shift tube the same distance from the top of the tunnel in all cars - but that is an assumption.
Regards
Hayden
Old 07-06-2005, 03:41 PM
