CV joint rotation
I did my usual search on PP and I haven't come a cross an answer so here it goes.
Are those inner and outer CV joints interchangeable? If so, is there a benefit to rotate CV joints? i.e inner and outer swap or left to right swap? I just think it may reverse the wears on the contact surfaces.
Old 05-29-2005, 09:41 PM
Left to right swap puts the forward load onto the typically unworn part of the ball bearing track.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 05-29-2005, 10:14 PM
Bird. It's the word...
Fishcop's Avatar
Yep, definitely interchangeable - and possibly like rotating your tyres, you'll get longer life out of the CV's.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-29-2005, 10:24 PM
if a CV has to much twist, like 1/4", I'd replace it.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-30-2005, 01:36 AM
Thank you for everyone's input. Maybe it's a personal preference, but what would be a rotation interval for left to right CV swap? For example, every 25,000 miles or 50,000 miles, etc?
Old 05-30-2005, 07:50 AM
IROC's Avatar
IMHO, it's too much trouble to rotate them at some random interval just for the heck of it. If you've got 'em apart, though, it doesn't hurt.
I rotated them once on a 944 when they started making noise and caught it just in time to keep from having to replace them. That was 9 years ago and they're still hanging in there.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-30-2005, 07:54 AM
Semper drive!
rcecale's Avatar
If you have a pre-1986 911, chances arre you have this version of rear axle. Note the cap screws on both ends which allows disconnecting it from the axle stub.
From what I've gathered recently, the inner and outer CV joints are the same part number, so can be easily interchanged or rotated.
In mid-1986, they switched to another axle which has the stub axle incorporated into the unit itself:
If the outer CV joint goes bad, you're looking at replacing the whole axle.
This drawing provided by Grady Clay shows the particulars:
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 05-30-2005, 08:14 AM
I'm not trying to make up a project just because I'm bored with the car. The rotation idea up because of CV joint lube schedule. From the reading, it is my understanding that CV joints have to be taken apart and cleaned before lubed. Well, since you have the CV joint apart at this point, why not go ahead and rotate the joints? Or, I could be just lazy and leave the joints alone until it breaks.
Old 05-30-2005, 09:15 AM
randywebb's Avatar
search for: long + term + maintenance + my name + grady
- I don't think there is any hard & fast answer for when you should relube the jonts. The shelf life of grease is about 5 years - that might be a useful guide.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-30-2005, 10:01 AM
Semper drive!
rcecale's Avatar
Mike
Mike,
When you rotated your CVs, did you actually disassemble them from the axle and flip them over? Or did you just flip axles from side to side?
Randy
One Marine's View
Old 06-26-2005, 07:28 PM
