}{arlequin's Avatar
Top of strut housing, help ID
Ok, I'll try to ID this stuff as much as I can w/o taking it apart. For now.
I'm swapping Boge struts in favor of Bilsteins and trying to take care of while-you're-in-there(s). The last one to consider is the top strut mounts.
Do these shock mounts (camber plates) look like regular stock pieces?
They appear rubber, so then all I have to replace is the center, rubber part, right?
I also read that some monoball inserts don't fit well w/ certain strut braces due to interference. Doesn't look like that's the case here, but what do you guys think?
dave
1973,5
Old 06-24-2005, 05:37 AM
}{arlequin's Avatar
bump.... and help?
Let me rephrase this... iff these are Weltmeister plates, is there a Weltmeister insert that could be used to refresh the strut mounts? Maybe a stock insert?
Will a Weltmeister accept a monoball?
(This is assuming I'm ID'ing the strut mount correctly as Weltmeister)
or...
"How would you refresh these strut mounts"
dave
1973,5
Old 06-27-2005, 12:55 PM
zachsbug's Avatar
I don't know if those are the correct mounts or nor but to refresh them go to the suspension wizard. Pelican has some poly mounts for sale. I'm looking to do the same thing to my car.
68 911 T
Ya lop eared Varmit
Old 06-27-2005, 02:03 PM
