So, where is this infamous sunroof drain?
Exactly where does this drain start and terminate? My rear driver side floor is getting a little wet from sitting in the parking lot when it is raining out. Not a problem i have had before...
Some pictures would be very helpful. thanks alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
UFLYICU
Too tight to get a pic inside the sunroof, but the drainhole begins all the way at the back of the roofline, inside the slot the sunroof slides in, and comes out behind the edge of the engine hood.
Driver's side: and passenger side: ![]() It can only be seen/reached with the sunroof removed. I would suggest a long, stiff wire of some kind to use to clear it. You might be able to do it from the holes in the pics, from outside the car.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 02-28-2004 at 10:45 PM.. |
Cool! So if i pour some water in the sunroof lip it should come out that hole. If it does not, how do you clean it?
alf
UFLYICU
I'm thinking giant pipe cleaner. Or something like that. Maybe a coat hanger with something on the end of it to push debris out. No matter which way you push the debris, you'll have to remove the sunroof to get to it.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Those are the sunroof drains? Whoah, cool! I've been wondering for like a month and a half what those were!! "Why is this !@#$ed water draining from these funky little holes," I kept wondering. Zoanas, you &^#*ing rock!
![]() Dan PS -- forgive my language, I tend to curse a bit more when I'm excited.
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
There are two more drains:
Look just above and slightly to the the right of the round black fuel filler neck collar. The yellow tube (the white tube crosses over it) descending down in an "s-curve" is one of the front sunroof drains. It runs down inside the the windshield support column ("A" column) and drains behind the front fender mounting fin. There is a matching drain on the front passenger side. We cleaned out the drains with a wire and compressed air; we actually blew out one of the small sunroof mechanism screws from one of the drains. Probably dropped in there some time in the car's past or maybe even at the factory. Cheers, Jim Last edited by Jim Sims; 02-29-2004 at 08:16 AM.. |
Alf,
Heavy gage weed eater line works well to clean the drains.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
This is difficult to see in focus but with the removal of the sunroof, you can see the opening in the rear corners.
Senior Member
Don't use any thing like a coat hanger.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
alf, your rear window seal is suspect also, check under your rear seats and rear shelf panel
ZOANAS, love those gloves
Damon @ SERIES 900.com Sunapee NH several 911 variants |
UFLYICU
Settle down, Dan. It's gonna be just fine. Be prepared for many more little surprises.
Jim, you're gonna have to step it up a notch and put some graphics into your photos. Don, outstanding suggestion. A coat hanger would probably scratch deep enough to remove some paint inside the tunnel. Wouldn't want to deal with rust in there. Alf, I would say you've gotten your money's worth out of this thread. Gratuitous, self-promoting, narcissistic, off-topic photo:
Thanks all for the great info!
Spent all my extra cash buying a digital camera with a good macro lense (for those close up shots); no funds for photo shop type software on this computer but maybe I can find some free ware.
Jim
UFLYICU
Looks like you spent a pretty penny on a ground strap, too.
Somebody beat me to the punch on the white nylon weedeater ( edge trimmer) line. Still be careful...there are ( I think) small rubber type connectors from the roof hard lines to the hard lines of the lower areas of the car. If you "poke" around too much or use too high pressure compressed air...I've heard of these connectors coming off and THEN you'll definately have water in your car !
----Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
The rubber hose connectors (two in the front and two in the rear) are there and if rotten or loose are a source of leaks and yes you can disturb them if the cleaning is too vigorous. We replaced them when we redid the headliner. Jim
Uno Dei Molti Porschisti
Sunroof leak through headliner - blocked drain & cable tube flange leaks
Just an FYI & thank you! With care one can avoid having to remove sunroof to fix leaks, using the info in these two threads, namely this one, and this one:
sunroof rear drain holes..leak (images incl) - Pelican Parts Technical BBS Wrote up my experience there as John Walker's comment was very helpful re cable tube flange leaks, which was part of my issue, and it also had the most recent content.
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024 ![]() Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon". |
