Me like track days
Need an idea for SPARE tire inflation........?
Currently I have a 996 TT spare tire and a can of fix-a-flat.
I have no lighter outlet for a tire pump. What I'd really like is a 'can' of compressed air rather than the compressed goop found in the fix-a-flat container. Where can I find this?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I think that used to be the standard in old GM cars. I'm not certain that it was just air, but I think it was. You may want to check a GM dealer.
Craig,
For dirtbiking, we all carry small CO2 canisters that fit into a tool with a small hose that runs to the valve stem. I have no idea if they will fill a car tire though. Or, if they will, how many canisters you would need. They are very small, we carry them in our packs (either a fanny pack or the drink style - camel back). Might be worth looking into..... -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Registered abUser
There are air compressors/pumps that can attach directly to the battery. A can of air could be completely worthless depending on the size of the puncture.
It would be real easy to hook up a ghetto ciggy lighter to the battery. It's just one + and one - wire. Keep it in the glove compartment and put some alligator clips on it. I'm pretty sure you can pick them up at any autoparts store cheap. You still need to carry the pump though.
Josh '87 911 Carrera 3.2 Coupe |
Go to Harbor Freight and they have 12 volt compressors for $15 to $20. I figured that since I would want to inflate the spare tire right in the front hood, I replaced the lighter plug on the compressor with 2 clamps that can clamp onto the battey terminals. So, I pull the compressor out of the smugglers box, hook the clamps to the battery and turn on the compressor.
PorschePilot 74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration MID9 Member Beechcraft V-Tail Bonanza (Fly'n high and low) |
Me like track days
Good idea - but I was heading for the trick idea of a can or cartridge of air.
Chris - Can you show me a site or source that shows the cartridges? I used to use the small ones (about the size of your thumb) for Mt. Biking
