S/W Ontario - Alignment Shop
Can anyone recommend a good alignment shop for my 911 SC in Ontario? The closer to Kitchener/Cambridge the better but I'll go far for a good shop.
Thanks,
-Rob
'79 SC
Old 06-29-2005, 11:38 AM
copper's Avatar
What about Furtmair in Cambridge? Not sure if they have alignment equip or not, but they're close.
RPP in London does it, Kryptonite had his done there. Fairly costly though I believe.
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 06-29-2005, 12:33 PM
Thanks Jim,
I just spoke with Furtmair. He outsources his alignment work to a shop in Breslau which I'll try. Because I only changed the tie rods to turbo tie rods he said 'Don't get a full alignment, just get a toe-in.' Hmmm...
-Rob
'79 SC
Old 06-29-2005, 12:48 PM
copper's Avatar
If you talked with Uli, he knows his stuff, and from what I'm told, his word, at least what little you get out of him, is good.
Brent at Whaletail may have a good recommendation for you also. I'll most likely be using them for my rebuild.
You can also call Dave Margolese at Eurotune in Caledon.
Jim
Old 06-29-2005, 12:51 PM
Used Up User
imcarthur's Avatar
Front will need toe & camber reset & caster checked.
You could always do it yourself if you have the time & place. It's not hard just very tedious to measure.
Ian
'87 Carrera Cab
Old 06-29-2005, 12:56 PM
