$730 and no improvement
I had the cam "O" ring seals replaced last week on my 911. Ended up costing me $730. Thats with an oil change. I had them replaced due to a oil leak on the left side of the car. The shop that did the work has done lots of work on this car over the past three years. Never a problem. Three of my friend also take there Porsche's to this shop for repairs. I've never heard anything negative about the shop at all. (Other than them being a bit pricey.) Great guys! Here is the problem. No change in the oil leak at all. How should I deal with this? Either they misdiagnosed the problem or the fix failed. Am I wrong in thinking they should pay to make it right even if they misdiagnosed the leak? Please, suggestions on how to deal with this.
1984 Carrera |
no question in my mind that i'd return to the shop with the car. if the intent of the repair was to stop the leak and it's still leaking i'd want to speak with the shop..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Sure, It it their responsibility. Unless you took the car there and said "replace the cam rings" and thatwas not the problem. But if they said that is where the oil is coming from and it is not fixed then they should make it right.
Be positive at first, dont yell, tell them that you and your 3 friends who all deal with their shop have had great results in the past, but you are a little disheartend that the oil leak is not fixed.
"Coffee is for Closers" "Push the button Max!!!" |
Shop I use in Houston has never billed me for missed diagnosis in the 7 or 8 years I have used them. And what makes this interesting is they also are saying I need to replace the cam seals. I'm holding off for a top end rebuild later this year but may move that date up with the amount of oil leaking all over the garage floor.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
PRO Motorsports
Any honest shop will take care of you and make it right. If you trust them, then there shouldn't be a problem getting this taken care of.
Have them check to make sure the cylinder #1 intake rocker shaft isn't leaking. (You said left side, right?) It can look like the same leak. Less common, but still a possibility.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
unless its burning on the exhaust or the oil leaks are huge amounts i would not worry about it.
Porsche 911 leak, after you fix one leak another one will pop up. Just place a mat underneath and save your money. Check with the mechanic, i could be in another area. jpc
Farmers Automotive 1-800-213-6373 http://www.farmersautomotive.com 1987 928S4,1989 911 25th, 1993 RSA, 1989 944,1988 911 1968 912, 1976 911 S, 1975 914 Engine dyno![]() http://www.youtube.com/watch?v=tJKdvrX_mTI&feature=youtube_gdata_player |
i don't think anyone here would argue that these engines were 'designed TO leak', but the reality of air-cooled motors such as these is that over the years a great majority have been operated and maintained poorly through either ignorance or lack of funds or both on the parts of series of owners. props to brian for what a porsche underside can look like..
ryan
Yes i believe you can fix the issue but if its not a daily driver and its not burning of the exhaust why worry.
Yeah i have sent thousand on oil leaks and really i should have not bothered in my mind. again just my 2 cents , it also depends on your environment temp. cheers jpc
Not fixing leaks is ghetto , that's funny!
Dime drops is not ghetto, heck most older muscle cars leak to. Again, your climate in california is different than the midwest. Heck cars from florida go through extreme heat. My 1989 25th avn 911 never leaked one dime but some of my other porsche did and i fixed them. cheers jpc
I think it depends on the year. I've had 2 86 Carreras that didn't leak for the most part and I was able to fix any leaks they did get. I've had 2 72 911s and couldn't keep up with the oil leaks on either one.
-Andy
72 Carrera RS replica, Spec 911 racer |
"They tend to leak from only a few common areas. "
Only a few: crankcase seam front crank seal rear (flywheel) crank seal Lower valve cover x 2 Oil pressure sender Oil temp sender Oil drain tube x 4 cylinder head-to-cam housing seam x 2 cylinder to crankcase gasket x 6 chain box cover x 2 Thermostat Camshaft oil line x 2 Chain tensioner oil feed line x 2 Crankcase breather cover Cam housing end plug/seal x 2 Camshaft O-ring x 2 Rocker shaft x 6 I probably missed something. :-) Some are easier to repair than others. Some require partial or complete engine disassembly. Sherwood |
GOT TURBO..
That is a warrenty issue, have them fix it. If they dont, push the issue a little bit. If they dont prep it right, it will leak. Ive done plenty of common leaks, and never got a call back for warrenty.. If i had done something to a car, and it was to leak, right to your house nocharge!!!! thats how a good word gets around..
I do goto modesto, once they fix it. Look else where to have your car done. Most my reffrences are on this board... |
Thanks everyone for the feedback. I also felt they were responsible. I just wanted to know how you all felt about it. I definitely want this leak fixed. Whats strange is if it sits for one to three days I might see three to four drips of oil. On the fourth or fifth day of sitting I have seen as much as a pint of oil. Like it all spills out at ounce.
1984 Carrera |
I think I know where you took your car. They are top notch people and I wouldn't even think twice about taking it back. You don't even have to get pushy with them. I can assure you, they WILL take care of it and make you feel comfortable about it.
They are doing my suspension upgrade and 3.6 conversion. My car is on the right side rack [black]. Drums
'89 G50 w/ 3.6 V-Ram-now Ca. legal! FORMER Yosemite Chapter PCA V. P. |
Registered Cruiser
Socal,
With engines that clean you must: A) Have a mechanic in a white lab coat on staff B) Be in the care of a whole team of psychiatrists C) Have no friends I was feeling pretty good about my valve covers until I saw yours....
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
I must insert this link, a homage to the oil in and from our engines - the lifeblood of the 911.
http://www.early911sregistry.org/CWelty.html Sherwood |
i enjoyed that link.
jpc
Hey Meka,
Did you talk to Keith and Bob, yet? If so, how was the outcome? Drums
