vibration when slowing
I'm trying to diagnose a strange vibration problem on an 87 Carrera. When slowing but not using the brakes there's a vibration that can be felt in the steering wheel. When the brakes are applied, the vibration goes away. There's no vibration at high speeds, only when approaching a red light or stop sign without the brakes on. It doesn't sound like an alignment or balance problem and seems to be confined to the right side only. Maybe a warped rotor or caliper problem? Any ideas?
thanks
c
Old 06-20-2005, 02:06 PM
Send a message via AIM to NoLift911
Have you jacked up the front and given everything a good shake to see what is loose if anything? Particularly the wheels. Bearing slop on the front wheels? Joints, steering linkages? Applying the brakes seems to usually stabilize things in the suspension that are worn or loose.
How many miles? Changed anything recently?
-Jeff
Jeff
Old 06-20-2005, 02:27 PM
aj88cab's Avatar
Several people have experienced the the right front caliper sticking on the Carreras. Check the tightness of the bearing. Then look at the rotor, is it original, maybe worn beyond specs, warping is a possibility. If the calipers have never been rebuilt it might be time. And while your in there you might as well do the bearings as well. Other items to look at..ball joints, tie rods, shocks, allignment. Any unusual wear on the tires?
Good luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 06-20-2005, 02:30 PM
buster73's Avatar
When coasting to a stop, the toe-in of the front wheel will change slightly. This might cause a vibration if there is some play in the front suspension (wheel bearings, tie-rods, bushings). Could also be shocks or some weird wear pattern on your tire. If you can't find anything obvious check the alignment.
Regards,
Guenter
73.5 911T, mod
Old 06-21-2005, 09:56 AM
Check to see if you have any loose lug nuts. Loose lug nuts can produce an identical symptom.
Ben Fegan
1988 Carrera Targa
Old 06-21-2005, 10:22 AM
jabb's Avatar
Look for cupping of the Tire Thread
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 06-21-2005, 11:01 AM
Just an update: took the wheels off and the rotors are badly worn. Don't have a micrometer but they're 22mm on the outside edges and I'd say there's at least a 1mm lip so they're long gone. I'll replace them this weekend and see if that helps. I've been reading the post on removing those PITA dust caps. Sounds like an interesting job. Also, I don't have a vice so getting the 5 bolts off the outer hub will also be a challenge I guess. Any suggestions? One at a time with the other on the ground?
There's nothing loose in the suspension and the bearings seem solid with no play inward or outward so hopefully it's the worn out rotors.
thanks
c
Old 06-23-2005, 07:38 PM
"When the brakes are applied, the vibration goes away."
Unfortunately I don't think replacing the rotors is going to take care of your issue...
-Jeff
Jeff
Old 06-24-2005, 07:33 AM
I think the culprit is a seized piston. I rebuilt the calipers today and the outside one on the "noisy" side was a little rusty and very difficult to get out of the caliper. It'll go back on tomorrow with new rotors so we'll see what happens....
c
Old 06-27-2005, 08:35 PM
All's well. I rebuilt the calipers and installed new rotors (they were in bad shape). No more noises. Thanks for everyone's help.
c
Old 06-29-2005, 06:44 PM
