Ignition Wires: Clewett vs. Magnecore
How do the Clewetts compare to Magnecore? Definite price difference ($130 for Clewetts vs $230 for Magnecores by our host). Also, heard the Magnecores are a pain to install (dizzy wire barely long enough, mounting brackets need to be drilled out to accomodate larger diameter, hard to press on connectors, etc.)
Any negatives regarding the Clewett's? My car is stock, so just need adequate spark. Plus they both come in RED, which is the real reason i want to change.http://forums.pelicanparts.com/newthread.php?s=&action=newthread&forumid=8# Mike '86 coupe |
I have found Magnecore's for $110.15 8mm blue wires and $142.90 8.5 mm red, I don't hink you would have to drill out the mounting brackets if you use the 8 mm blue wires
Phil 2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift 1988 911 coupe (GP white) Turbocharged 1998 BMW 328i |
I just did the Clewett's (red ) for my 83SC, would have done the Magna's, but as usual, temp. out of stock/ Very happy with Clewetts.
Rika |
no gripes about the Clewetts I put on a couple of months ago....
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
You can save yourself the trouble unless looks are more important than function. No problems without them: ![]() 86 3.2 Cheers, Joe Last edited by stlrj; 07-02-2005 at 09:34 AM.. |
For most OEM applications they use a split sleeve loom to protect the cables.
I didn't use my factory hardware either, but did get a pack of seperators from Clewett...
Clewetts are fine. I don't think there's much quality difference if any.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I just installed the Magnecors this morning and did not encounter any of the problems about fit I have read here on the forum. Just listen for the "click" and remember the plugs are at a slight angle to the valve covers. Everything went very smoothly. I did drill out the wire separators and it only took about 3 minutes to do all of them. Connect the separators back together and hold in a bench vice. Drill out for K85's to 8.0mm. It was easy!!!
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Registered Cruiser
Thought I read somewhere that Magnecor MAKES the Clewett pieces....
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
Doesn't want/need a 3.6L
A little "creative" routing needed to get Magnecor's (12) plug & (2) coil wires attached to the 993 distributor, as space is tight but not that big a deal. The Magnecor's are worth any extra effort IMO. Ralph |
where do you get the separators? i don't have them with my magnecore's and they definitely clean things up.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
You can use the stock Beru wire separators. Just spray lubricant like WD-40 on the 8.5mm cables that you will buy and inside the separators and they will slide. This is what I do to my 911. I use MSD 8.5mm cables with the stock Beru spark plug wire separators.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
On a stock 3.2 with AC, what parts do i need to remove (if any) before i can access/replace the ignition wires? Are long, double jointed, skinny arms needed, or will i spend most of the time removing stuff, just to gain access to the spark plugs?
thanks mike
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
Mike, I just did this and it helps to remove the long S shaped plastic duct from the heat blower fan on the left side. On the right side just remove the A/C compressor which takes all of 2 minutes to do. Just lay the compressor on the rear fender and put a cushy thick towel on the fender first obviously. Then just take your time.
I went with the 8mm Magnecor's and routed them myself without the stock Beru holders. The engine bay looks a bit crisper without the Beru holders IMHO. The Magnecor's are superior in construction and fit next to the Clewetts. I did a ton of research before I bought them at http://www.apexperformance.net/cartgenie/hotdeals.asp Good luck
Just because I don't care doesn't mean I don't understand! Gordon Ost '85 Carrera Cab '01 Durango 5.9 R/T '00 Taurus SE- SO's canoe '97 KTM 250EXC FOND MEMORIES: '68 Pont Ventura Conv 389w/trips '99 BMW 323is '71 TR-6 very first car '73 TR-6 restored it-Concours winner '67 Lincoln Conti-suicide doors '70 Challenger-340-6pack slap stk '69 Dart GTS 440-4bl-4spd '73 Moto Guzzi Eldorado |
Mike, here's some shots that may help ya.
BTW-our host sells both brands I believe, might want to watch the competing links.
I put the Clewetts on my 79' SC. I was having problems with the plugs sealing to the valve covers. The car ran poorly, but come to find out I was sent the wrong plugs. I actually talked to Richard Clewett himself during the ordeal. Great support.
79' 911SC 98' 911GT2 Evo RC ![]() 84' 944 (Sold) |
gost--sweet looking engine!! Nice "Carrera" script on the shroud--did you make that?
Mike
Mike, thanks for the compliment. I just finished quite a bit of work on the car and cleaning up the engine bay was one of them. My girlfriend's an artist and she airbrushed the CARRERA on the alt housing strap which was now available to do so after i tossed the Beru wires and holders. I think the bay looks so much nicer without the Beru stuff on it.
One of the things I did wqas to powder coat the Alt fan and housing and it came out sweet. My girl matched the housing color for the lettering and then slightly highlighted the tops of the letters with a whitish frost. She made her own stencil after I gave her the classic carrera lettering and I think it came out awesome as well. It added a personal touch to the car and made it unique. Thanks again for the compliment, she'll be happy to hear it. Oh and Ed by the way the 8mm Magnecors I purchased were $119. Our sponsor has the 8.5mm for over $200, way overpriced. Nothing wrong with saving money and this forum informs you of the best deals around which is why it's so great. Pelican has plenty of competitively priced items and I purchase from them often but you have to keep em honest. Gordon
