| Registered Join Date: Oct 2004 Location: Ancaster, Ontario, Canada
				Exhaust Flange bolts & Nuts
			Silly question but I don't have a Bentley manual yet. I'm changing out my muffler and cat for a Dansk pre muffler and sport muffler and I want to have bolts and lock-nuts in advance but I don't know what size. There's no way I'll be able to reuse the old hardware except for the muffler clamps.  I can't find the size in the Pelican catalog. Could one of you let me know. Thanks | ||
|  07-04-2005, 05:04 AM |
			bump
|  07-04-2005, 10:51 AM |
| Registered |
			Do you have a set of digital calipers that go from ins to mm? They are abt $12 on ebay.  measure what you have and replace with SS nuts, washers and bolts.  Use nylock nuts and antisieze compound.
				__________________ If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) | ||
|  07-04-2005, 11:44 AM |
| Registered |
			I just did this, I wouldn't recommend nylock, I think it would melt in a flash.  Search a bit and you'll find, Will Ferch listed out the exact hardware required.  I used HW from mcmaster.com, SS bolts and SiBr nuts, worked out nicely.
				__________________ David Avery 05 Lotus Elise (sold) | 08 BMW 135i visit FocusedE, my e-business company | visit Spyderclub | ||
|  07-04-2005, 12:28 PM |
| Registered abUser |
			I recently took my cat off to install a bypass pipe and bought the following replacement hardware at Home Depot for about $8. Not metric, but convienent and cheap. 9 ea. 5/16-18x1 1/2 hex bolts stainless steel 9 ea 5/16-18 hex nuts stainless steel 9 ea flat washer zinc coated Last edited by TerryH; 07-04-2005 at 01:51 PM.. | ||
|  07-04-2005, 01:49 PM |
| Registered Join Date: Feb 2003 Location: Orange County, California
			TCB, most of the stuff on my turbo exhaust from the heads to the flanges is 8mm with a 13mm OD and for some tight areas 8mm with 12mmOD. and I'm sure it's the same for yours. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_exhaus_pg6.htm | ||
|  07-04-2005, 02:22 PM |
| Registered |
			Terry, Stainless will gall, you may want to get the silicon bronze nuts.  I'm pretty happy with it, they were pretty cheap.  May want to get them off while you still can.
|  07-04-2005, 05:19 PM |
			Wow, I did a bump cause I thought this was too trival a question and didn't expect so much input.. THANKS TO ALL - -  it helps.  I'm dying to change out the exaust, I want a bit of rumble, after all IT'S A PORSCHE !!! | ||
|  07-04-2005, 05:40 PM |
| Registered abUser |
			Thanks for the tip, David. I used high temp anti seize. Hoping it won't have to come out again for about 10 years.     | ||
|  07-04-2005, 05:57 PM |
